Turbo time. . . .
Old Apr 5, 2007 | 08:40 PM
  #126
hes a wheeler, hes a dealer, hes lww!!
Old Apr 5, 2007 | 11:09 PM
  #127
apollo's Avatar
Pro Pumpkin Carver
Originally Posted by lww
Now that I have another 240Z, I need that drive shaft as a core... BUT... How about I give you my drive shaft NOW and when Bleach comes down for MSA, he can bring his drive shaft and you can trade the 2+2 t-tops for it, then give me his drive shaft to replace the one I gave you...
There! How's that? You get your car running right away and I'll have a drive shaft when I finish the T5 swap in my white 240z.
Done and done. Sound good Bleachie?
Old Apr 6, 2007 | 12:02 AM
  #128
rock on jake. hope it runs better than snws .
your so gay..... lol. hey, least i know my problem is due to running rich so i do the timing injectors AFM gotta work itself out, if not, tax return will be here ill go MS get my DSM injectors put my pallnet fuel rail on then i odnt gotta worry bout non of that dumb **** i cant go hmm.... its rich, and tune it down. lol.
oh yah an apollo, its realy no big teh wiring, its a few power wires 2 to the battery, you need a signal for start another for ignition (run) or maybe its 2 wires for that, a few grounds and if your gonna have your fuel pump run the same as before and not re wire it another wire for your fuel pummp relay 2 wires for teh ignitor, a wire for teh tach... its really no big. sit down look at these write ups for a while and it'll make sense
http://www.zcar.com/forums/read.php?...34996&t=334996
http://forums.hybridz.org/showthread.php?t=84860
http://www.zcar.com/forums/read.php?...2#reply_557682
sure they are for S30's but teh wiring harness is the same so you just tie tehm into the same connections on your car look at a wiring diagram you can figure it out, i had to cause tehre were no write ups directly for a 260Z most were actually for 280z's actually so tehy were already EFI. just do it!
Old Apr 6, 2007 | 07:52 AM
  #129
dont forget the 280zx takes a signal from the oil pressure sender to run the fuel pump. if that isnt integrated, it can really suck. apollo do the maxi fuse upgrade, it will remove all the fusable links, and make powering that beast easier.
Old Apr 6, 2007 | 08:24 AM
  #130
check out my turbo swap thread. I think I put some info on the wiring in there towards the end.
Dont' forget to pull the little coil wiring harness from the turbo car. Leave your NA wires for the coil in place for now as well. My thread talks about how I used those power and ground wires to power up the turbo coil.
Ya, the driveshaft for t-tops trade sounds good. I'll bring it down with me.
Old Apr 6, 2007 | 08:58 AM
  #131
apollo's Avatar
Pro Pumpkin Carver
Shweeeet. You heard the man, lww. Its go time!
Old Apr 6, 2007 | 10:41 PM
  #132
lww's Avatar
lww
Head Muckraker
Rock on, my Turbo Z bruthas!
Old Apr 10, 2007 | 05:42 PM
  #133
apollo's Avatar
Pro Pumpkin Carver
So with the driveshaft now in the Z its just wires that keep her fmro running. So im looking around, asking who i can have help with that **** when it occurs to me . . . .why not have the Z specific mechanic at work do it!!! DUH!! Not only will it be warantied work, but at the unbeatable playa price i was offered i couldnt refuse. No fuss, just drop it off, and for around 100 bucks and 3-5 hours wait time i got a running Z. Then just smog, and its GO TIME.
Old Apr 10, 2007 | 05:50 PM
  #134
entropy31's Avatar
The Cake Is A Lie!
cheater....
Old Apr 10, 2007 | 05:52 PM
  #135
apollo's Avatar
Pro Pumpkin Carver
Haha, i aint cheating. Im just being efficiant
Old Apr 10, 2007 | 09:53 PM
  #136
so does that mean you'll be driving to the Z nationals with us?
Old Apr 11, 2007 | 07:16 AM
  #137
He muthah effin better!
Old Apr 11, 2007 | 07:18 PM
  #138
apollo's Avatar
Pro Pumpkin Carver
Quite possibly . . . .I just had it towed to Nissan. Come Monday, it should be running * knocks on wood*. Now, since its a dealer and im just a lowly employee, I get knocked down the totem if customers need work done. So lets just hope those good ol Nissans around the greater bay area can hold off from breaking or needing routine maintenance so I'll be in and out.
Old Apr 12, 2007 | 05:08 AM
  #139
Good luck brother, and congrats on your successful swap.
Old Apr 12, 2007 | 07:01 AM
  #140
you mean you may go to msa apollo??!!?? thatd be too cool
Old Apr 12, 2007 | 07:21 PM
  #141
apollo's Avatar
Pro Pumpkin Carver
Quick question . . . . .im thinking of getting the turbo radiator rebuilt. Good idea or nab a new one? Pirce isnt so much the issue as is i am just tired of working on the Z:i wanna drive it now. Is there a direct/semi-direct fit aftermarket one?
Old Apr 12, 2007 | 08:11 PM
  #142
get a new core put on the old tanks, go 3 core dense. they work great and can cool anything. doing this is cheap and efficient
Old Apr 12, 2007 | 10:39 PM
  #143
radiatorbarn.com right there.... they are awsome... they are better than stock slightly, they are almost a diy radiator, same mounts and location for inlet and outlet but idk, they arent stock you know? they label them as a diy anways why, i dont know. they also got performance as for a zx though, idk if they do. a stock replacement one will be about 180 dollars though but tehy are brand spankin new and shiny!
Old Apr 13, 2007 | 08:49 AM
  #144
You can get generic Griffen track aluminum radiators brand new for 180.
Be warned, they have no mounting tabs. Yes, none at all. You have to build a "tray" of some sort to hold it in top and bottom. weird. They say "universal mounting" which means no mounting tabs. Summit Racing sells them
Old Apr 13, 2007 | 07:49 PM
  #145
apollo's Avatar
Pro Pumpkin Carver
Yea i was thinking griffin. I dunno, i guess i'll just stick it out till its running and see if it even needs aftermarket cooling.
Old Apr 13, 2007 | 10:44 PM
  #146
only 180 for agriffin rad? wow too bad i spent more than that re-coring mine
Old Apr 14, 2007 | 01:39 PM
  #147
why spend $180 on repairing a radiator when you can buy a brand new stock or aftermarket one for the same price?
I wouldn't spend more than $70 on any repairs. Its not worth it.
Old Apr 18, 2007 | 06:31 PM
  #148
apollo's Avatar
Pro Pumpkin Carver
SWEEEEEEEET!!! So the Z got some love from Nissan today. We went over the wiring and he just wont hard wire anything. Doing the **** all legit. Kinda sucks cuz now i gotta pull hella more shti from the turbo car. Mainly the fuel pump control modulator. Dunno what it does, just that he wants it and its harness. So work will commence manana and with the luck of the Z gods and Jims millions of years of Z experience it shoudl be all good and RUNNING. Then to DMV for a day permit to get some exhuast and finaly to a "special" california state referee for a smog. * mr burns voice* . . . .Excellent . . . .
Old Apr 18, 2007 | 06:38 PM
  #149
entropy31's Avatar
The Cake Is A Lie!
kickass news jake. wish i could make it to MSA to see it (dirty taxman )
Old Apr 19, 2007 | 10:33 AM
  #150
You will make it to MSA Jake, not like my local Z32 friend here...
I dont' know what that fuel pump module does either. You saw my build. I never used it at all and my car works fine.
