A/c Problem
Old Jul 23, 2007 | 03:14 PM
iluvJDM's Avatar
A/c Problem
EDIT thread title: A/C Problem!
Im surprised that its taken me so long to ask about this since i live in hot *** miami lol, but about a year ago my A/C crapped out. Basically the blower still works even tho it makes a horrible screeching sound when i turn it on (bad belt i guess) but the air doesnt come out of the vents...i played with all the switches and nothing. This happened out of no where, my a/c used to work fine and one day i turn it on and no air comes out of the vents. What can it be and how can i fix it? Thanks
Old Jul 23, 2007 | 03:46 PM
The vent problem is common & there's been a lot of threads about it. The vents are controlled by vacuum tubes. If there is a leak or crack in any of those tubes, the vents won't work & it will default to blow through the floor vents only.
Old Jul 23, 2007 | 04:02 PM
iluvJDM's Avatar
yes thats right it only blows thru the floor vents now that i remember! Sorry i didnt know it was brought up before, can you post a link to the thread that has the solution or can you tell me what tubes they are? thanks again nismo
Old Jul 23, 2007 | 04:53 PM
Using the secret word "vents" in the 280zx Search section yielded the following (plus much more!).
https://www.zdriver.com/forums/showt...ighlight=vents
Old Jul 23, 2007 | 06:25 PM
iluvJDM's Avatar
ok well the only revelent one out of those 4 links is the first one, and it mentions whats wrong and then the thread just ends with you guys talking about your bimmer...no solution as how to fix the problem. Can you be so nice and tell me what needs to be done with the boxy thing with all the vacuum lines that snwbdrphat described? so i can finally get my air working again
Old Jul 23, 2007 | 06:58 PM
hey ive got a perfect 81 s130 blower fan and an r200 diff if you wanna buy them..
also check to make sure the blower fan is still working...
Old Jul 23, 2007 | 07:19 PM
Banshee's Avatar
Yeah that thread pretty much goes nowhere. find the canister on the passenger side of the firewall and check the feed hose and the ones going into the firewall. if there aren't any cracks or leaks you should may need to replace it?
Old Jul 23, 2007 | 10:18 PM
duckyz's Avatar
It might not be the blower he's talking about squeaking...
If the blower doesn't work, look for the glass fuse up under the dash on the passenger side and replace it. Get your yoga stretching in!!! Your head will be on the floor and your feet up on the headrest.
Myzsucksass
Nov 28, 2013 06:58 AM
turbo84z
Oct 10, 2006 07:30 AM
HybridS130
Sep 2, 2006 05:50 PM
pearly whites
Oct 30, 2003 01:37 PM
saaddaa7
Oct 24, 2003 08:19 PM
