A/c Problem
EDIT thread title: A/C Problem!
Im surprised that its taken me so long to ask about this since i live in hot ass miami lol, but about a year ago my A/C crapped out. Basically the blower still works even tho it makes a horrible screeching sound when i turn it on (bad belt i guess) but the air doesnt come out of the vents...i played with all the switches and nothing. This happened out of no where, my a/c used to work fine and one day i turn it on and no air comes out of the vents. What can it be and how can i fix it? Thanks |
The vent problem is common & there's been a lot of threads about it. The vents are controlled by vacuum tubes. If there is a leak or crack in any of those tubes, the vents won't work & it will default to blow through the floor vents only.
Originally Posted by iluvJDM
can you post a link to the thread that has the solution or can you tell me what tubes they are? thanks again nismo
https://www.zdriver.com/forums/showt...ighlight=vents https://www.zdriver.com/forums/showt...ighlight=vents https://www.zdriver.com/forums/showt...ighlight=vents https://www.zdriver.com/forums/showt...ighlight=vents |
ok well the only revelent one out of those 4 links is the first one, and it mentions whats wrong and then the thread just ends with you guys talking about your bimmer...no solution as how to fix the problem. Can you be so nice and tell me what needs to be done with the boxy thing with all the vacuum lines that snwbdrphat described? so i can finally get my air working again
hey ive got a perfect 81 s130 blower fan and an r200 diff if you wanna buy them..
also check to make sure the blower fan is still working... |
Yeah that thread pretty much goes nowhere. find the canister on the passenger side of the firewall and check the feed hose and the ones going into the firewall. if there aren't any cracks or leaks you should may need to replace it?
It might not be the blower he's talking about squeaking...
If the blower doesn't work, look for the glass fuse up under the dash on the passenger side and replace it. Get your yoga stretching in!!! Your head will be on the floor and your feet up on the headrest. |
