Car just quit and now won't start!! HELP!!!
Old Aug 8, 2012 | 09:28 AM
FlyAssMelonBall's Avatar
Unhappy Car just quit and now won't start!! HELP!!!
Hey i was driving my car went around a corner and i just quits. At first i thought i was out of gas but that wasn't it, so we thought it might have been the timming but it wasn't, so we checked the ignition and we weren't getting a spark so i took the ignition coil to autozone, they tested it, and they said it was no good. So i ordered one, put it on yesterday and it still won't start. I'm still going to check a few ignition things but please help. When the car quit it just quit no clunks or bangs fyi.
Old Aug 9, 2012 | 01:16 PM
AZ-ZBum's Avatar
unplug your air flow meter and try again
Old Aug 9, 2012 | 07:07 PM
rogerz's Avatar
Grumpy & Helpful
my general advice
Clean the connectors for the maf, ecu and tps. Deoxit by CAIG is probably the best connector cleaner on the market. spray with CorrosionX after cleaning and before putting together this will help prevent any further corrosion.
Old Aug 10, 2012 | 01:30 PM
Ok so im not getting power to the ignition system is it possible a relay went bad? I will check those things but where would i get good terminal clamp? And whats tps?
Sorry i'm a noob.
Old Aug 10, 2012 | 04:20 PM
Ok so im getting power to the distributor cap but not out of it, the distribu was replaced but idk about the crank angle sensor.
Old Aug 10, 2012 | 04:22 PM
right now im clueless
Old Aug 10, 2012 | 05:13 PM
rogerz's Avatar
Grumpy & Helpful
tps equal throttle position sensor. you don't get power to the dizzy cap you get high voltage which should then go to the sparking thingys. if that be the problem a rotor would be a nice thing to have. like i said lots of things on the z31 depend on your battery and cables being in A one condition. if you refuse to investigate that then why are you posting. download the fsm from xenon. THEN READ IT.
Old Aug 10, 2012 | 08:49 PM
Ok i did check the battery and the voltage is fine. But but what would be the battery wires and clamps i need? Do you mean like crimp styled clamps? One thing we thought could be a problem in the distributor theres like a metal disc and it has like a little black lip over it, i was wondering if something could have happened to the black lip part?
Old Aug 11, 2012 | 03:40 PM
ok so i think im going to replace the rotor. When i looked at it the tip was black, so idk if that means anything, but i sanded it off and got nothing.
snwbrderphat540
Apr 12, 2007 10:25 PM
DGriffin
Mar 10, 2007 10:29 AM
BigEkak1941
Feb 23, 2005 06:45 PM
Bert
12
Dec 18, 2003 09:57 AM
dave547
Apr 29, 2003 10:39 AM
