It was goin great, Then quit!?!
Old Nov 11, 2003 | 09:10 PM
theramz's Avatar
I have a present for you...
Could be your injectors. Try switching # 6 with # 1 and see. If it fouls in #1 hole, it's your injectors. If it still fouls in #6 hole, then it might be a clog some where in you smog system. Maybe your EGR valve.
Old Nov 12, 2003 | 08:59 AM
Before you go through the work of removing the injectors, try removing the wire clips on the back of the injectors and cleaning those connections well. It does sound like an injector problem.
Also double check the spark plug wires and the connections there. Make sure the distributor cap is on good and the timing bolt didn't come lose and turn your ignition timing retarded. Then give the ECU a couple wacks with a hammer!
preludetwofast
Aug 22, 2010 08:44 PM
snwbrderphat540
Feb 10, 2006 03:40 PM
NismoPick
Nov 13, 2005 07:00 PM
VenomousZX
Sep 1, 2005 04:54 PM
DarrellBuddy321
Jun 29, 2005 08:41 AM
