How to make the N/A Faster?? swap mass merge thread
firstly... the only problems to date are high idle (one very easy to change sensor or something), brake rotors, and front end bushings. possibly sub frame bushings, but i reckon i'm going to do something ghetto there pretty soon.
secondly, wow, that is one VERY expensive 30 HP.
it sounds like one should focus more on the rotating mass rather then the crank power though.
i would be shocked if i didn't see a nice difference in wheel power if i added a one piece drive shaft, lightened flywheel, and all new exhaust with headers.
what do you all think of that combo? will it give me a decent little amount of power?
http://cgi.ebay.com/ebaymotors/XTD-P...mZ190206915400
what do you think of this one? $240 shipped and it's only 12 lbs. is it crap?
http://www.conceptzperformance.com/C...424.19.201.171
that's what i figuired. thanks for taking the time to talk to me about this. i got kinda exited about the prospect of more power and i'm sure glad i didn't spend any money on it without researching.
but what is there to be wrong with that flywheel? you think that it wouldn't actually be the weight that they advertize? or that 12 lbs. isn't really much lighter then stock? or it might fly apart lol
Hi, im new here, i have a 300zx na and i was wondering if the na engine is stronger enough to handle a big single turbo or if ill blow it up. If the power gain is worthless or the money invested really worth the mod.
thanks
sorry about my english, i'm french....
thanks
thanks
thanks
you won't be able to run much boost, as the NA engine has high compression, 10.5:1 or so. turboing the NA motor is generally considered a poor option.
also, please use the search function before asking questions, as this topic has been covered many times. thanks.
.also, please use the search function before asking questions, as this topic has been covered many times. thanks.
thanks for the info, i should think about selling it to buy a TT maybe
srry about that :S
Hi, I recently found some one that might sell me a damaged 300zx tt but the frame is broken so i can't repair it but I though about maybe an engine swap and transmision ( mine is auto and the damaged car's transmition is manual ) or just take off the front clip of the damaged one and put it on my n/a. What do you think about it and why? thanks
(srry if it's a repost but i searched and didn't find anything)
so how about cam shafts for the N/A? i did a search and found a lot of shaft sets for $900-1100 that said good for 450-600 HP cars. i'm guessing that since the 450 isn't attainable, these are all only good for turbos? any cams for the N/A?
thankyou! that did indeed answer my question. like i said, i got bored about half way through reading this sticky and probably just missed that. thanks though. so the quoted 375 HP N/A on youtube is probably bs then aye?
i'm still a little bit in denial that this car can't be upgraded at least enough to notice. it's coming to me though. i was thinking if i threw cams into my prior list, then i may make my goal. kinda just want to beat a stock TT by the time i'm done. and i don't mind if it takes a long time. but i am willing to accept defeat on this one. still researching it
Hey this is my 1st post and I just got my car about 3 months ago. I got a 90' 300zx. I cant afford to do a tt swap. but i do want it fast. I put in a Jwt pop charger and have the platinum bosch spark plugs. I need to put on a new exhaust system. So after that should I just put a 100hp shot of NOS in it? I can get it cheap so does that sound like the way to go.
2. Pop charger and exhaust will NOT make significant gains. MAYBE 10 hp.
3. you'll blow your engine up if you just toss a 100 shot of NOS on it.
fast is not cheap. period.
