Mod updates
Old Jul 17, 2005 | 04:41 PM
  #151
bardabe's Avatar
Bad Speller
wht turbos are you planign on using? i am considering on Using teh Garrett GT28RS turbos. with HKS actuator valves and COZ 5 bolt down pipes. with soem research i figured outt that teh Garrett GT28RS are the same as the HKS 2035 ball bearing. (yes the garret's are ball bearing as well) any inputs on this?
Old Jul 17, 2005 | 06:10 PM
  #152
91zxtt's Avatar
I'm looking more along the lines of AMZ's stage 1 or Z1's GT525's since both bolt to the 4-bolt pattern downpipes.
Don't you mean the HKS 2530's? The turbo's you're looking at pretty big and very pricey. Those are the same as the JWT 700BB turbos; which have a tremendous amount of lag.
Old Jul 17, 2005 | 06:36 PM
  #153
bardabe's Avatar
Bad Speller
my bad typo i want the GT28R not RS.
Old Jul 23, 2005 | 07:51 PM
  #154
91zxtt's Avatar
Can someone explain what exactly this means...(duration and lift)..I get the basics, but which cam is built for higher performance. If I understand this correctly, the Z1 CAMS are ground a bit more on the performance side than the JWT's are. The HL-14's stay open longer, but don't open as much, correct? The HL-15's are open longer and open wider than JWT's; which = greater performance, right?
Z1's HL-14 cams are 270 degress duration and .365" lift
Z1's HL-15 cams are 270 degrees duration and .385" lift
The JWT 100's are 262 degress duration and .368" lift
The 400's are the same +4 degrees advance on the exhaust cam L.C. (recommended for 400-600 HP cars)
The 400+'s are 264 degrees duration and .375" lift + 4 degrees again.
(recommended 450-650 HP cars)
(Not sure what the L.C. means)
This is what I'm considering...
http://www.z1motorsports.com/product...roducts_id=952
or
http://www.z1motorsports.com/product...roducts_id=953
Unless there's something wrong with my pistons, I've decided the I'm not going to go far enough into it to change the pistons, rings & rods. I'll stick with larger turbos, cams, Stage 2 or 3 head work, & ported exhaust manifold. I'll likely run 19 psi - 21 psi max with the larger turbos.
Old Jul 23, 2005 | 08:03 PM
  #155
91zxtt's Avatar
Oh, I meant to also let you guys know that the engine is just about ready to come out. Need to drain the oil and the tranny fluid, remove the driveshaft, unbolt the lower control arms and the tension rods. That should just about cover it. It actually doesn't look like it'll be that bad. I'm crossing my fingers.
With the engine out, I guess I can finally replace that damn EGR valve. I think I'll look into removing the HICAS as well. I guess I'll need to install an N/A power steering pump and fluid reservoir. That should really clean up the engine compartment a lot and lighten her pretty substanstially.
Old Jul 23, 2005 | 09:36 PM
  #156
b300z's Avatar
caught the z fever
linkies no workies...
i found this tho...
We are looking at definite valve lift increases to take advantage of higher lift flow capability and increased valve duration to enable higher RPM potential. This is the typical rationale behind this build-up, but there are some issues that need to be addressed. Although the flow substantially increases at the higher lifts, is the motor actually benefiting from the increased flow capability at lower RPMs?
from...
http://www.wighat.com/fcr3/camtruth.htm
also maybe something in...
http://www.elgincams.com/campaper.html
are you sure you dont want to upgrade everything so you dont have to strip it all down again...just like your motto
so how long do we have to wait now to see it back together and running purrrfectly? I hope not next year.
Old Jul 24, 2005 | 01:47 AM
  #157
bardabe's Avatar
Bad Speller
wouldn't it be easier to just loosen the motor mounts and break out the Hoist?
Old Jul 24, 2005 | 12:35 PM
  #158
Mousier158's Avatar
i have removed hicas on my tt. theres a couple meathods...get the hicas lock that stillen, spl, and many others sell...or swap the rear subframe to an N/A rearend. visit Z1motorsports under their tech section they have a very informative article. Dont forget when using an n/a p/s pump you need the matching bracket for as the tt p/s pump mounts slightly different...i made this mistake.
Old Jul 24, 2005 | 08:36 PM
  #159
91zxtt's Avatar
Thanks for the heads-up on that. I never would've guessed that the brackets would be different. I like the SPL HICAS eliminator since it comes with tie rods. It looks like a cleaner conversion.
Old Aug 1, 2005 | 07:45 PM
  #160
91zxtt's Avatar
Engine's out. It came out farily easily; which was a nice surprise. Dad pulled the heads off today. All 6 exhaust valves on the driver's side made contact with the pistons. I intake valve hung up on one of the exhaust valves. Pistons & cylinders look flawless. Turbo's are absolutely destroyed, but it wasn't caused by this most incident. It's amazing they made any boost at all. All this time I thought the DINAN chip wasn't programmed right or that my boost jets weren't drilled right, but it appears that the turbo's were the culprit. I'll post picks later. I didn't have my camera with me.
And considering that the car is my parent's place, there's no way it's going to take as long to get it back together. Probably a couple months. Maybe by my birthday (October 3rd). Cross your fingers.
Old Aug 2, 2005 | 05:53 AM
  #161
CanyonCarver's Avatar
Jack Of All Trades
Bad as in turbines rubbing the housings?
Are you getting the heads rebuilt? .... or replacing? Maybe for fun, ask the head shop about going to a li'l bigger valves?
Old Aug 3, 2005 | 09:22 PM
  #162
91zxtt's Avatar
Who knows. Something got in there and just shredded the turbines on the intake side. When we disassembled it, nothing was in the pipe, so whatever it was, it was ground up and spit out. Hell, it could've been like that since I bought it. I'll never know.
Attached Thumbnails Mod updates-pass-2.jpg   Mod updates-pass-3.jpg   Mod updates-driv-1.jpg   Mod updates-driv-2.jpg   Mod updates-driv-3.jpg
Old Aug 3, 2005 | 09:24 PM
  #163
91zxtt's Avatar
Engine bay needs some serious cleaning. I need to reconnect the cross memerb and steering box so I can roll it outside. It'll make a mess, so I'll have to do it when Dad isn't there.
Old Aug 3, 2005 | 09:25 PM
  #164
bardabe's Avatar
Bad Speller
does it have any shaft play? one word and one series.
Garrett GT28R
same as HKS GT 2538. cheaper, and still Ball bearing.
Old Aug 3, 2005 | 09:29 PM
  #165
91zxtt's Avatar
This is why it won't take as long to get the car back together. Keep in mind, this is Dad's garage.
Old Aug 3, 2005 | 09:31 PM
  #166
91zxtt's Avatar
Garrett GT28R
Shaft play isn't the problem. Lack of fins on the turbine is the problem.
Old Aug 3, 2005 | 09:34 PM
  #167
91zxtt's Avatar
This is what the engine looked like coming out.
Attached Thumbnails Mod updates-mvc-001s.jpg   Mod updates-mvc-002s.jpg   Mod updates-mvc-003s.jpg   Mod updates-mvc-005s.jpg
Old Aug 3, 2005 | 09:36 PM
  #168
entropy31's Avatar
The Cake Is A Lie!
wow 91, those turbos look nasty. no wonder you werent getting any boost.
Old Aug 3, 2005 | 09:41 PM
  #169
91zxtt's Avatar
Here are some shots of the heads and the block. The exhaust valves are the ones that are kind of a light brown. #6's exhaust valves are black. #6 is the hole that had the faulty injector. I think I can safely assume that was truly my smog problem.
The block looks very un-assuming once you've removed all of the other crap.
Attached Thumbnails Mod updates-driv-head.jpg   Mod updates-pass-head.jpg   Mod updates-cylinder.jpg   Mod updates-1-3-5.jpg   Mod updates-2-4-6.jpg
Old Aug 3, 2005 | 09:43 PM
  #170
91zxtt's Avatar
Yep. I'm going to clean them up and use them as paperweights at the office.
  #171
bardabe's Avatar
Bad Speller
uhm. no enigne slingers. not very safe. they where made for a reason. btu yeah. looking good. that hoist dosent look safe either.
Old Aug 3, 2005 | 10:00 PM
  #172
91zxtt's Avatar
We made mounting brackets that bolted straight into the heads. 2 bolts per side. IMO, better than where the FSM recommended to lift it out. The FSM way is extremely unbalanced. This was pretty easy.
I agree in regards to the hoist. It's not ours. We borrowed it from a friend. I'm considering just buying a new one so I'm not a basket case when we put it back in.
Old Aug 3, 2005 | 10:55 PM
  #173
entropy31's Avatar
The Cake Is A Lie!
that'll be cool. i had a chief in the navy who was a 1st and 2nd gen rx-7 guy, and he had one of his old rotors made into a clock. maybe polish one of them turbos up and try something like that.
Old Aug 3, 2005 | 11:54 PM
  #174
Riz Z Speed's Avatar
Administrative Brown Guy
man, i'm so wishing i lived near you so i could help.
as dissapointing as the results are, i'm thinking how much fun it would be to rebuild your engine. Of course it's always more fun when it's someone else's car.
Old Aug 4, 2005 | 03:53 AM
  #175
Jack Of All Trades
I'll never think my garage is a mess again. you can definitely see where the valves hit the pistons.
