Mod updates
Originally Posted by 91zxtt
I installed a screen to replace the one missing on the dummy maf....problem fixed. I can't believe that something as insignificant as a screen would have this large of an impact.
yeah it burns cleaner... but for our cars especially yours its gonna knock alot... just run horrible... why do you have to assume im making a statement in the way your thinking?
why am i so luckily selected by you to get ridin on?
Yes, it'll run like ****, but it'll pass smog. It'll only knock if I'm running in boost; which I obviously wouldn't. The plan is to run the car nearly out of gas, put in just enough 87 to get me to and from the smog shop. then I fill it up with 91 again.
You're the chosen one because you don't think before posting. You should try it sometime.
I've read that type of fuel additive is basically an octane reducer, so it's basically the same thing.
I don't have an adjustable FPR. I've also read I can disconnect the vacuum line to the fuel dampener. There are a lot of things to do 'make it pass'. Up to this point I've always wanted to find the problem and fix it. Now I've found out that with my mods, it likely won't pass smog anyways. So, it seems I don't have a problem. I just need to find a shop that will work with me.
DAMM smog jerks
i hope What i have said helps you out bro hit me back if you want to ask something I'll tell you want I know, or what I might think about what your asking. I'm pritty good at figuring out hard stuff. I hope you pass bro good luck
Originally Posted by Boosted Z
wait until you check mine out when im done.
also, if you install an adj FPR, fuel maps will need to be tuned to use it properly.
i say, just get it done, smog it, and enjoy it for now. its been too long
you do not realy have to tune fuel maps, you just want the fuel pressure to be controled better and be at the proper fuel pressure for your injectors
Originally Posted by b300z
make a new thread about your Z. im curious
I washed it and parked it nicely in the garage so that I can work on it when I have more time, money and patience.
Amy and I just sunk about $85k into our house (pool, landscaping, concrete), so the Z has taken a backseat for now. I figure if I don't do much with the Z, then Amy won't nag me to get rid of it...j/k...I think she knows that if she ever she did that, I'd smack her with a shovel and feed her to my catfish.
