Differential bucks under accel and decel
I know the differential mounts are shot on the car but I can't find any poly mounts and would much rather get poly than spend 140$ on a NOS mount and 50$ on new subframe bushings. Does anyone have a line on these? (Acadiana does not have either the mount or the bushings in stock at the moment)
Also on a side note need to find 2 star shaped hub caps for a 1986 Z31 NA.
And the throwout bearing is making a good bit of noise, so how easy is a Z31 trans to remove and stab?
Thank You,
Jack
Thank You,
Jack
You might try a tube of buetal rubber on the mounts , as a temp fix I have
also check other manuf. For a bushing thats close mitsu for one
the trans r&r about normal if you have a 6ft lift and trans jack
Fast240Z
09-24-2006 08:32 PM
