Question on Accel Universal Coil
Old Dec 7, 2009 | 09:20 PM
attacksoma's Avatar
I was wondering if anyone here uses the Universal coil from Accel.. What are your impresions on it? Do you guys recomend it?
Old Dec 7, 2009 | 11:28 PM
just stick with the stock coil.
Old Dec 8, 2009 | 12:35 AM
skib's Avatar
This facepalm's for you!
meh, nothing wrong with it. Its a coil, it makes spark.
your not going to magically get more HP putting it in or anything.
Old Dec 8, 2009 | 03:48 AM
FubarI33t's Avatar
I tryed it. My engine was burning so much oil i needed the extra spark power to geet the plugs from fowling out. It worked for about 15 miles, then could not power the engine over 1500 RPM, took it back got the silver one, same thing just about 15 miles. I droped in a Solid coil from a N/A Z31. worked great and kept the plugs cleaner for a couple hundred more miles. Still runnin it to this day with the new engine. All you need it the stock Z31 plug, Coil, and two good wire crimps. No other adjustments needed(for 82-83)
Old Dec 8, 2009 | 02:46 PM
Niku-Sama's Avatar
eff good grammar
i used a Blaster 2 coil, it helped smooth things out a bit
Old Dec 9, 2009 | 10:06 PM
attacksoma's Avatar
I just got the car a few months back and was fixing to change most of the stuff on it , not sure when the last owner did the tune ups... But thanks for the feed back
IMSA RX300
Nov 23, 2011 08:31 AM
Niku-Sama
Mar 21, 2008 10:47 PM
280ZX_AV8R
Jun 3, 2005 01:16 PM
Indys300zxboy87
Oct 7, 2002 11:20 PM
zphreak
Jul 8, 2002 05:30 PM
