Digital to analog.. Im stumped
Old Sep 16, 2012 | 01:14 PM
ricksilvia's Avatar
All right peeps I did the digital to analog gauge cluster swap...BUT I am confused... I have it all working. But the ancient computer behind the glove box that controls the warning system requires 2 female adapters to plug into each end of it.. the analog harness has 2 males? NismoPick HELP
Old Sep 16, 2012 | 04:33 PM
You use the analog dash harness for the analog cluster, digital dash harness for the digital cluster.
Old Sep 16, 2012 | 04:54 PM
ricksilvia's Avatar
such vast knowledge the analog harness doesn't fit the warning computer
Old Sep 18, 2012 | 02:33 PM
Yes it does. Well it does if you take the analog pig tail out of a car with the warning computer. If you take it out of an analog car that didn't have a warning system.....
Old Sep 18, 2012 | 05:45 PM
ricksilvia's Avatar
thanks bro i ended up wiring the old digital ends to the analog harness had to add a pin or two... works like a champ now!
Old Sep 18, 2012 | 05:51 PM
ricksilvia's Avatar
Quick question..
I did the digital to analog swap in my 83 280zx. all gauges are working. i didnt change the temp sending unit but im still getting a reading. a very high reading. is this accurate? why or why not? Thanks for the constant help
Old Dec 9, 2012 | 07:32 PM
aruiz714's Avatar
AHHH! I swapped mine and the temp. reads at 3/4 of the gauge. Was i suppose to change the ect sensor?
Old Dec 9, 2012 | 09:16 PM
Don't think so. Might have some extra resistance in the harness somewhere - connector to the sender (temp sensor)? Could also be a faulty gauge....
Old Dec 9, 2012 | 10:40 PM
aruiz714's Avatar
Thanks buddy
greeley82zx
Jun 23, 2012 11:20 AM
tdbaker156
Feb 17, 2012 01:19 PM
bluekroz
Aug 2, 2010 04:14 PM
Charlie
Nov 1, 2005 06:55 AM
Jonvg30et
16
Aug 8, 2005 06:16 PM
