problems
Old Oct 19, 2004 | 01:04 PM
Spak339's Avatar
problems
About 4 days ago i got my car back from the shop the get my brakes done... on the way home the car run fine, parked it in fount of my house and 2 days later when i go to put it in the gerage it starts missfiring and not have much to look at it i left it there, well when i came back to it yesterday to see if its still having problems, i went to start the car and it did not want to start. It did but then shortly after it stalled. the carbs also poped about once or twice...
so any ideas on whats up? im about to pull the pluges to see if they are bad
thanks
Adrian
Old Oct 19, 2004 | 10:02 PM
myxtaz's Avatar
thanks
Adrian
Not much to go on but check the ignition. How long since a tune up? Could be bad plugwires , is the weather wet or vary damp? Do you have points ? If so look to see if they are burnt or pitted. Many times pops through the carb are caused by lean senttings on the carbs, but check the ignition first. You can't just let the car set and hope the problem goes away and come back and all is well , at least not where I live . LOL
Old Oct 21, 2004 | 03:09 PM
Daeron's Avatar
next time, do your own brakes, theyre easy. :- p
BUT you should check out the possibility that the brakes (somehow) caused the problem.. see if holding the brake pedal down while starting or running the car makes any difference... if it does, try disconnecting the big vacuum line that goes to the brake booster and plug it. see if that helps. i dont know that it will, but your problems started with a brake job, and this is the only direct connection between the brakes and the engine, so its worth a shot.. there is a check valve in line between the manifold and the booster, and that goes bad sometimes.
ZBspires
Aug 30, 2013 07:33 AM
86z31
Aug 16, 2010 06:14 PM
turbo84z
Jan 21, 2008 02:26 PM
duowing
Sep 30, 2006 08:26 AM
hondahunter
Mar 18, 2003 02:45 AM
