cam and EFI problems
Old Mar 16, 2003 | 10:49 PM
auxilary's Avatar
the Dude
That's the whole point of a race cam - to make lots of power in high end. You can play with your timing, but don't expect to get a lot of stellar results.
Old Mar 17, 2003 | 10:52 AM
auxilary's Avatar
the Dude
mudge, do you think he could piggyback an s-afc type unit, or maybe replace the 280z ecu with an sds fuel management unit?
I was driving to work actually thinking about this question, and I was going to recommend an FPR as well.
Old Mar 17, 2003 | 12:49 PM
Do you really think its running rich at idle, or is the long duration just causing you to have lower compression at low rpms? That is typically what you have with a race cam and that gives you a rough idle.
However, it is true that the Z fuel injection leans out at higher rpms. Richening up the mixture through all rpms and adding the rising rate fuel pressure regulator are ways to help keep the fuel flowing at high rpms. Don't worry too much about your low rpm power. If you want that back, either try advancing your upper cam sprocket to the #2 position (with a new timing chain) or just put in a shorter duration cam.
The advanced cam will close the intake valves sooner and help raise the static compression of the engine. High end power may suffer slightly, but mainly above 5500rpm.
If you have a high lift cam and/or have shaved your head make sure you are going to have enough clearance for the valves to clear the pistons.
Old Mar 17, 2003 | 03:34 PM
I have heard of some people who built the forced induction Megasquirt for the turbo six. Maybe if we find someone who has a built unit for an L6, they can give us some numbers for a base to start from. Then it just needs to be put on a web page for reference.
That actually is a good idea for a fuel injection setup. It sure is a lot more time consuming.
ZBspires
Aug 30, 2013 07:33 AM
86z31
Aug 16, 2010 06:14 PM
turbo84z
Jan 21, 2008 02:26 PM
duowing
Sep 30, 2006 08:26 AM
k-link
Jun 13, 2005 09:39 AM
