300ZX Z32 Tech Tips For 90-96 Z32's.
How to make the N/A Faster?? swap mass merge thread
Old Jan 30, 2005 | 06:36 AM
  #226
00Evan's Avatar
Banned
I didnt see that you already had a parts car.
BTW you dont need to weld any IC brackets. Everything bolts right up.
Old Jan 30, 2005 | 06:59 AM
  #227
lightspeed's Avatar
Southern Speedster
People buy Z's because they are wonderful cars, they handle well, go fast in any trim, and look great.
People typically buy NA's for a reason - cost, reliability, insurance, back seats, cosmetics.
People typically by TT for a reason - normally the incredible speed and ease of making even more. Power is quite intoxicating.
Think about what you want in a Z before you buy it. If you buy a NA, it will not make the power of the TT without a LOT of money. And your TT will never have a back seat without a LOT of money.
Old Jan 30, 2005 | 08:31 AM
  #228
CanyonCarver's Avatar
Jack Of All Trades
There's not too many people interested in a fast n/a. I guess it's because a tt swap, or buying a tt, is so easy..... :burnout:
When I was out on the streets of willow yesterday, I was happy to have my n/a.
Old Jan 30, 2005 | 07:02 PM
  #229
91zxtt's Avatar
They run about $350. If you find one for significantly less than that, then I would be wary. It probably isn't Nissan OEM. Concept Z and AMZ sell them for $350.
Old Jan 30, 2005 | 07:19 PM
  #230
91zxtt's Avatar
I'm starting to get sick of seeing people recommend a TT swap. Everyone talks about it, but nobody does it. Let's try to bring this site back to the real world.
For the record....the majority of the people that talk about doing a swap do not have the $, the know-how, or the required equipment. Unless you can do the swap yourself, it is much less expensive to buy a TT. The much simpler task is selling the N/A and buying a TT.
Old Jan 30, 2005 | 07:40 PM
  #231
WhtFairLadyZ's Avatar
I like the exhaust note of a N/A. But cannot resist the rush when the turbos spool and the sound they make doin so.
Old Jan 30, 2005 | 07:43 PM
  #232
What do i do about the mounts on the chassis brace right above the headlights? Can I just leave those alone, or will the hard pipe kits elimnate the need of them?
Old Jan 30, 2005 | 07:47 PM
  #233
bardabe's Avatar
Bad Speller
ahleluya!!! thank you 91.
Old Jan 30, 2005 | 08:01 PM
  #234
00Evan's Avatar
Banned
they arent necissary. there are other mounting points for the IC pipes, that extra one isnt really necissary
Old Jan 30, 2005 | 08:22 PM
  #235
Other than the engine wiring harness, you will need the tranny too. Unless you want to take the time to modify the mount for the starter. You'll need it too. The TT flywheels are larger than the n/a. You'll also need a different exhaust system since the n/a wont bolt up to the pre-cats.
It would be easier to just get a frony clip. That way you'll get the oil cooler and all other brakets and stuff.
As for the interior, you'll need to mount a boost gauge. I haven't heard go reviews of the factory units. But they do work. It may not me a necisity, but I like keepin an eye on things
Old Jan 30, 2005 | 08:51 PM
  #236
00Evan's Avatar
Banned
The NA exhaust bolts up to the JDM precats
Old Jan 30, 2005 | 10:04 PM
  #237
bardabe's Avatar
Bad Speller
ok I have good advice that has bin given to me. if youare gonna do a JDm TT front clip. when Uhave the motor outof the clip.order a Engine rebuild gasket set from Courtesparts adn change all teh gaskets. so U might also want to check for any maintenance need to be done. this is my plan.
Step 1. get the frotn clip.
Step 2. remove the motor fromt eh Clip
Step 3. check for any damage on motor. and replace allt eh gaskets.
Step 4. change the flywheel and clutch.
step 5. do the 120,000 Mile maintenance
Step 6. clean all conectors and plug in new harness.
Step 7. replace O2 censors.
Step 8. assemble motor back up.
step 9. get a TT fuel pump
step 10. wire up the turbo timer and electronic boost controller.
step 11. set up intercooler piping and drop int eh Intercoolers.
step 12. change the transmition oil and gear oil.
step 13. re do the air conditioning and power steering lines. and all other gizmos and gadgets the TT has diferent than teh N/A.
step 14. drop in the motor and do all the truble shooting need (not to mention there WILL BE MANY)
Step 15. Go Look for some supras.
Step 16. :rockon: :rockon: :rockon:
and all this will take time. so like 91ZXTT said "if you don;t have time to do it right the first time, do U have time to do it over?"
Old Jan 30, 2005 | 11:41 PM
  #238
tangeray's Avatar
lol...thanks allot barbade, and everyone for that matter. This past weekend brought me some bad news that might put my engine swap plans on hault. The dude who sold me the car forgot to tell me that the radiator lower support beam (or the front crossmember) was Cracked!!.. The car shimmys at 60+ MPH and shimmies on braking. Im in the process right now of getting a new one. I saw one for 157 bucks that i need to change out. ALso, Im feeling a loud Thump in the *** end when I switch gears. Is that the Differential or in the tranny itself does anyone have experience??
~~MOral of the story is now I got bigger fish to fry. It sucks....
~Tangeray
Old Jan 31, 2005 | 12:47 AM
  #239
Riz Z Speed's Avatar
Administrative Brown Guy
let's not make this a trend by resurrecting old threads.
thread closed.
Old Jan 31, 2005 | 12:48 AM
  #240
and again with the old threads....
Old Jan 31, 2005 | 10:18 AM
  #241
bardabe's Avatar
Bad Speller
lol tell me about it. the thumpis normal Ithink we all get it. at least me and all of my z friends. changing the trany and diferential oil helps.
Old Jan 31, 2005 | 10:49 AM
  #242
00Evan's Avatar
Banned
thump isnt normal, its either the diff or subframe bushings
Old Jan 31, 2005 | 02:40 PM
  #243
tangeray's Avatar
Has anyone ever done a front cross member/ radiator core support? I found one online for like 157 bucks + shipping and Im probably gonna do it this weekend. My buddy is an OK welder. If anyone has done one, please give some tips.
~Tangeray
Old Jan 31, 2005 | 07:48 PM
  #244
91zxtt's Avatar
I'll 2nd that.
Tangeray....can you post a picture of it? I would really want to know how it happened and whether or not you're going to find more cracks elsewhere?
Old Jan 31, 2005 | 08:12 PM
  #245
tangeray's Avatar
k...when I get home tonight I'll post pictures of the Crossmember. Im not exactly sure how it happened because the dude I bought the car from got it like this 2 weeks ago. Im guessing it happened awhile ago because it looks to have been welded at least once before as a TEMP fix.
~~Im trying to figure out how to change my tranny and diff oil this week sometime. Anyone got any quick pointers?...
~Tangeray
Old Jan 31, 2005 | 08:26 PM
  #246
91zxtt's Avatar
Yes, you can find those suggestions in Rizz's link page.
Old Feb 1, 2005 | 03:45 PM
  #247
z32dude's Avatar
Hey, how's it going? When shopping for a 300 how much of a concern is mileage if I plan on replacing the engine right away?
Old Feb 1, 2005 | 03:50 PM
  #248
tangeray's Avatar
Well......The mileage on your chasis then is basically all your concern. Now this entails EVERYTHING THOUGH>>. Im talking rear diff, brake systems, suspension, body stuff, etc..etc.... Im not the expert, but as I have been reading the forums and into the Z's, nowadays mileage really isnt a factor because most people are swapping motors, doing conversions, etc..etc... Ask your seller the history of the Z and what parts have been changed out and which parts havent. Hope this helps....
~~Tangeray
Old Feb 1, 2005 | 04:11 PM
  #249
z32dude's Avatar
~~Tangeray
Yeah I was thinking along those same lines... Oh well, I guess I'll have to fork over the extra cash just to rip the engine out and fork over even more cash to put a new engine in... Damn college, it's taking all my money, but then again in about 5 years I'll be making enough to buy a few ZX's.
Old Feb 1, 2005 | 07:12 PM
  #250
ryzcar91tt's Avatar
i use 94 from sunoco seems to work very good
