Info on upgraded turbos?
I'm swapping my NA Z and thinking of going with some aftermarket turbos while I'm at it. Finding information hard to come by though. I'm trying to do some research and learn about strengths and weaknesses of different ones but good information is hard to come by. Anybody have any suggestions or know where I could find a few good writeups to check out or places to start? I really want to get some good research in on this.
https://www.zdriver.com/forums/300zx-z32-forums-7/what-turbos-32042/
Any turbo upgrade (any turbo larger than stock) is going to require an unpgraded ECU (even the smallest aftermarket turbos - JWT Sport 500s - have a wastegate preset of 12psi, which is more than your stock fuel maps can handle), larger injectors (even at 12psi, a Sport 500 will flow more cfm than your injectors can reliably compensate for), and at LEAST basic upgrades (intake and exhaust), else you risk reliability issues from choking the turbos (which will land you right back where you are now) or overboosting the engine (which will land you at a machine shop having the motor rebuilt).
Sport 500s are a fantastic inexpensive upgrade. Spool like stock and have great power output for the cost. Keep in mind, though, any aftermarket turbo is going to require basic upgrades to work efficiently (intake, cat-back, downpipes, and ECU at least, intercoolers and injectors if you know what's good for you).
Aftermarket turbos?
Does anybody know any good writeups about aftermarket turbos for 300's? I'm trying to do some research and check out some comparisons but information seems to be hard to find. Thanks!
maserom
08-28-2013 07:10 PM
jaredjmoore89
56
02-10-2008 08:20 AM
