Speedo cable removal
Old Apr 12, 2013 | 12:02 PM
PredatorZ's Avatar
84 z31, taking the dash out. I have almost everything disconnected. I can see the back of the speedometer and the cable going in, just cant see a way of getting the cable off. Any hints ?
Old Apr 12, 2013 | 12:26 PM
I've never messed w/ a Z31 dash, but I imagine an 84 isn't much different from a 280zx. There should be a large plastic ring around the end that you twist loose (connecting to the speedo / back of gauge cluster). The 280zx has a 1ft extension cable that unscrews right at the firewall.
The usual removal method requires getting upside down w/ your head at the pedals and legs up on the seat, and stick your arm up to unscrew it.
Old Apr 12, 2013 | 02:55 PM
PredatorZ's Avatar
Got it
There's a plastic clip you have to get you hand in there press on both sides and it pops out, not easy but doable. Minus a little skin and half a dozen cuts later. Better than last week, nicked an artery 8 stitches and about a pint of blood later the VA had me fixed up, kinda set me back a week. But now there isn't a bit of the interior left, just sheet metal and the harness in a heap.
Attached Thumbnails Speedo cable removal-int-1.jpg   Speedo cable removal-int-2.jpg   Speedo cable removal-int3.jpg
Old Apr 12, 2013 | 03:04 PM
PredatorZ's Avatar
pics
Here's the connector, as you can see there's a place to press that releases the 2 tabs on both sides.
Attached Thumbnails Speedo cable removal-speedo-con-1.jpg   Speedo cable removal-speedo-con-pressed.jpg
feifongwong3
Aug 4, 2010 02:44 AM
speed280zx
Nov 18, 2008 08:21 PM
speed280zx
Nov 7, 2008 10:46 AM
Niku-Sama
Jul 27, 2008 06:05 PM
zbuild
Feb 12, 2001 01:06 PM
