Fuel pump not priming & ECU interpretation
Old Jan 18, 2017 | 02:57 AM
beersushi's Avatar
Hi all,
My '89 Z31 Californian had been running fine, however over the weekend decided to conk out while idling at a set of lights and has refused to start since.
The issue I suspect is Fuel Pump related as when turning ignition to On I'm not hearing the familiar short buzzing sound which I believe is normally an indicator of the fuel pump initialising/priming. The car trys to crank, but cannot start as I suspect no fuel is being supplied.
As all power in the car appears OK (lights/indicators etc) I do not believe this is fuse related.
I also tried self-diagnosing the issue via the ECU indicator lamps but cannot make heads or tails out of the light sequences as to whether an issue code is being presented, I took a short video if anyone with expertise can assist interpretting the code? (I'm trying to reference the codes list for '89 @ http://xenonzcar.com/z31/ECUcodes.html).
Video of ECU diagnostic output: https://youtu.be/rd4yLHPpYQg
Would love to hear any opinion of ECU output or if anyone has had a similar issue they solved where the fuel pump doesn't appear to be initialising when turning ignition to on?
Old Jan 18, 2017 | 08:31 PM
86tcoupe's Avatar
if it has 2 gal. of fuel it should pump , the fuel pump motor sets in the fuel .
1st thing is a fuel flow /pressure test not hard to do but not really for a novice either ( not saying you are , just it can be dangerous if done incorrectly )
refer to the manual you can check if you have a complete circuit to the pump when cranking
I'm dealing with a rusty tank /inop fuel pump too.
Old Jan 18, 2017 | 08:57 PM
Either no power is getting to the fuel pump, or the fuel pump is toast. Break out a multimeter or test light, test for power when ignition is turned on. If no power, check relay, check fuel pump ground. If power, replace fuel pump.
Old Jan 19, 2017 | 02:00 AM
beersushi's Avatar
Added another 2 gal tonight "just in-case" the low fuel indicator was not working correctly, but alas no difference but worth a shot.
I'll have a read of the manual regarding circuit check and see if it offers any hints.
Old Jan 19, 2017 | 02:04 AM
beersushi's Avatar
Getting the feeling fuel pump might be toast but will see if I can pickup a cheap multi-meter and at least confirm suspicion before I go down replacement path.
Old Jan 19, 2017 | 02:33 PM
rogerz's Avatar
Grumpy & Helpful
stick a pressure gage in the line before the fuel ring. get a reading because listening and hoping don't get it. you probably have a fuel problem.
Old Feb 9, 2017 | 01:59 PM
86tcoupe's Avatar
best look in the tank or pull it . a few flakes of rust through the screen and it seizes with the design ... I have a new complete assy. I might sell ( bought it for mine but the tank is junk IMO )
EliHellstrom
Sep 24, 2015 01:16 PM
professor229
14
Apr 15, 2013 05:56 AM
Doomfinger
Dec 6, 2012 01:51 PM
sameerb1
Mar 20, 2011 05:21 AM
ern
Oct 20, 2006 07:01 AM
