Do I need to change the fuel pump fuse to a 15-20 amp for a walbro 255 lph pump?
Old Oct 19, 2006 | 06:52 AM
ern's Avatar
ern
Just recently, my 10 amp fuse for the fuel pump is blowing out ONLY from time to time? I've checked the wiring and all seems OK.
Old Oct 19, 2006 | 07:11 AM
Are you talking about the fusable link by the battery? Or did you wire the fuel pump yourself? If you ran your own wiring, you should prolly use a 25 or 30 amp fuse, but there should be something in the pump instructs that indicates what fuse to use.
Old Oct 20, 2006 | 07:01 AM
ern's Avatar
ern
No its the fuse in the fuse box on the driver's side. No I didn't run my own wiring. To make matters worse when I bought the pump it didn't have any instructions with it....crappy!
jmitch
Jun 21, 2012 06:21 AM
sameerb1
Mar 20, 2011 05:21 AM
chrischicoine18
May 25, 2006 11:46 AM
nismo613
Apr 10, 2006 05:24 PM
SoulZ31
Nov 21, 2003 12:22 AM
