Car died while driving down the road???
Old Oct 29, 2012 | 09:39 AM
Spiffy McYiffy's Avatar
I pulled out the dirveway it shifted to 2nd fine and it wouldn't go into 3rd drove about 200 feet and lost 2nd and another 200 feet and to wont move at all, got it back home and when i try to start it i just hear the starter turning and its not even turning the engine, was wondering if anyone knows what the problem is before i start tearing it apart...thx in advance
1985 N/A automatic just turned 100k miles
Old Oct 29, 2012 | 10:03 AM
zenzee's Avatar
85 zx na no starter action
Check battery first for 12volts. Sounds like a voltage problem.
Old Oct 29, 2012 | 12:05 PM
did that and swaped starters and no change?
Old Oct 29, 2012 | 12:48 PM
ThaPimpShrimp's Avatar
What do you mean when you say the starter is not even turning the engine?
Old Oct 29, 2012 | 02:01 PM
tested the starter and its working properly, but the engine is not turning over (when it started normally the belts and fan would turn when trying to start) but in this case there not
Old Oct 29, 2012 | 06:17 PM
The starter is rotating but is not turning the flywheel. The motor is not locked up but the engine will not turn over with the starter, just can hear the starter rotating.
Old Oct 29, 2012 | 06:35 PM
rogerz's Avatar
Grumpy & Helpful
you better get another set of eyes on it with you. If the starter is turning (assuming the bendix is throwing out). then the flywheel has to rotate. if the flywheel rotates then the engine turns over. Either the bendix is not working or you have the mystery of the ages ongoing. Are you sure the starter you swapped was any good. Or you got two burnt solenoids on two different starters.
Old Dec 30, 2022 | 04:51 PM
n0youcant's Avatar
[urgent] same here
[QUOTE=Spiffy McYiffy;318034]I pulled out the dirveway it shifted to 2nd fine and it wouldn't go into 3rd drove about 200 feet and lost 2nd and another 200 feet and to wont move at all, got it back home and when i try to start it i just hear the starter turning and its not even turning the engine, was wondering if anyone knows what the problem is before i start tearing it apart...thx in advance
[urgent] this just happened to me and I’m currently stranded at the side of the road. If you fixed this or know how to fix this. Pls let me know. Thank you in advance
livinzlife
Aug 29, 2007 07:46 PM
SportBikeMike
Jul 18, 2007 10:04 PM
OlderThanMe
Dec 15, 2004 06:15 PM
jesusfreakz
Oct 20, 2003 03:02 PM
insomniac67j
Sep 26, 2002 04:15 AM
