WreckedJ30's Z31T ecu conversion
Old Dec 11, 2006 | 06:43 PM
  #101
Originally Posted by captken
Well, if the donor turbo ECU came out of a car with a 17mm. O2 sensor then you have modifications to make. [titiania]
The 87-89 ecu's used the different O2 sensor, this is an 85T.
If the car came with a 22mm. [zirconia] 02 sensor then you are good to go, problem lies elsewhere.
Indeed it does.
I supplied a 88 turbo ECU for upgrade and additional steps are required to make it work [properly] in my application, '83zxt.
kenny.
Yeppers... the JWT ecu upgrade requires an 88-89 n/a ecu & some different re-wiring than the 84-86 Z31T swap.
When you get your new ecu running, we'd love to hear how it goes!
Old Dec 11, 2006 | 06:51 PM
  #102
captken's Avatar
[/QUOTE]
When you get your new ecu running, we'd love to hear how it goes![/QUOTE]
Well, I supplied them an '88 turbo ecu, thats why I have to do a wiring harness to ecu upgrade and a downpipe bung hole upgrade.
I can assure you that I will post the results of a killer plug and play, no hassel no drama, [I hope] upgrade of my car.
I hope you find the source of your problems.
Old Dec 11, 2006 | 07:14 PM
  #103
wreckedj30's Avatar
No Club Love
yeah i don't no WTf. I was driving it after i swaped in the speedo from Shady, And it died, and wouldn't start. Just like one of them wires were disconnected from the ecu again. Then when it did start, and i was uping the rpm to move it, it died. So i don't no, smells hella rich again, and won't go anywhere, it did this 5 times. Oh and then after it didn't idle anymore. So next jy trip, i'm getting a new Maf, chts, and some parts for the s30...Hopefully it'll work when i'm in cali, before the swap.
Old Dec 11, 2006 | 07:58 PM
  #104
captken's Avatar
I hope you figure it out.
Old Dec 11, 2006 | 08:08 PM
  #105
wreckedj30's Avatar
No Club Love
yeah, were brothers....you have a problem! no why cause we have stupid problems, man that **** sucks, i think it has something to do with my spark plugs/ wires or distributor. something electrical. after i swap out the manifold, cause it has something to do with vacuum problems, then it should be fixed...
Old Dec 11, 2006 | 08:09 PM
  #106
wreckedj30's Avatar
No Club Love
why did you edit that, i saw what you wrote
Old Dec 12, 2006 | 01:30 AM
  #107
xtreme 2's Avatar
hey guys. so I am getting ready to do the Z31 swap, and I am getting the wiring ready to go and have a few questions... first go is the MAF... in the tutorial is shows that the wiring changes are:
CONNECTING THE MAF:
Cut the wires to the AFM a few inches back from the clip
Take clip and wire from MAF then:
1) Connect MAF Position A/wire 30 y/g to 30 y/b wire from z harness
2) Connect MAF Position B/wire 31 b to 31 y/r wire from z harness
3) Connect MAF Position C/wire black to body ground
4) Connect MAF Position D/wire 26 b to 26 b wire from z harness
5) Connect MAF Position E/wire 27/35 b/w to any ignition activated + powered wire (pin 27 and 35 are + ignition wires on the same circuit, they are b/w (black with white strip) and can be tapped into from either b/w wire going to the 2 V.C.M solenoids that are located under the AFM bracket
6) Connect MAF Position F/wire 12 r/w (for cleaning cycle) to 33 y/l wire from z harness
Now, I see how all of the colored wires run in, but wires #2 and #4 are confusing me... all they say are "b" wires, and after matching up the colored wires I am left with a black wire with a blue stripe on it and then a thick gray wire, which when stripped shows a black covered wire wrapped in aluminum wiring...
which of these 2 wires goes where?
should help greatly with the swap since it isn't too clear...
Old Dec 12, 2006 | 06:40 AM
  #108
captken's Avatar
Was funnin' only! Sometimes the posts are hard to follow.....
Old Dec 12, 2006 | 07:10 AM
  #109
Take off the rubber boot that covers the wires on the MAF plug so you can see all the wires as they come out. Then you can clearly see which wires are A through F. The wire w/ shielding... you need to cut back the shielding & connect the inside wire. Do not allow any shielding to touch the inside wire.
Old Dec 12, 2006 | 10:05 AM
  #110
xtreme 2's Avatar
cool thanks for the info... makes it much clearer...
Old Dec 12, 2006 | 10:07 AM
  #111
es de uh... was that sarcastic?
Old Dec 12, 2006 | 11:02 AM
  #112
y2daniel1981's Avatar
I hope it's not sarcasim and it really is clear because it's my car he's doing it on!
Old Dec 12, 2006 | 11:03 AM
  #113
Well get over there n make sure he's doin it right!
Old Dec 12, 2006 | 11:07 AM
  #114
Oh if only it wasnt 2 hours away and I didnt have a final tonight
Old Dec 12, 2006 | 11:08 AM
  #115
xtreme 2's Avatar
haha no I was being serious.... the tutorial was talking about 3 different black wires and I had no clue which was which.... but by taking the boot off I can see that they go in order down the harness... didn't even think to take it off...
Old Dec 12, 2006 | 11:10 AM
  #116
xtreme 2's Avatar
so now when doing the ECU wiring, is it easier to just modify the stock 280 harness or to splice in the Z31 harness? we have both, so I am just curious...
Old Dec 12, 2006 | 11:41 AM
  #117
Just use the pins from the Z31 ecu plugs & insert them into the 280zxt ecu plugs. I just used a dremmel to open up the plastic & pull out the pins.
Old Dec 12, 2006 | 11:44 AM
  #118
wreckedj30's Avatar
No Club Love
so Nismo, if i get a mega squirt setup would you want to do a tech session again?...and i might be able to bring up the zx, after the swap for you...Tehe, thread jackers..lol
Old Dec 12, 2006 | 11:48 AM
  #119
MegaSquirt is a "whole nuther world." I've actually never done anything w/ it... so I could help ya install it... but trouble shooting will be fun. Ya got a laptop to tune it?
Old Dec 12, 2006 | 11:57 AM
  #120
wreckedj30's Avatar
No Club Love
hmm, i can probably borrow one, but i haven't got one myself...i got an idea, if i can get all the ****, done swaping the .et motor in the 240z. Then when msa comes up you can come down, and help with it...Then sport your zx and the z at msa...That'd be badd...I know this is off topic, but what all is needed for the turbo swap into the z. Like driveshaft is what i'm worried about?
Old Dec 12, 2006 | 12:11 PM
  #121
If the car was running before, just swap engines... the tranny will bolt right up. If you use the T5 tranny, you'll need to shorten the driveshaft & use the T5 driveshaft diff flange.
Old Dec 12, 2006 | 12:16 PM
  #122
wreckedj30's Avatar
No Club Love
so that means try and find someone to shorten my tranny then huh, ****. I knew that would be a bitch....the car comes with a 4 speed but i'll probably just keep it for extra....damn and this megasquirt instructions are hella confusing, damn i'm going to need some help....Well Nismo i'll give you a rolling shell for help with installing this here megasquirt.
Old Dec 12, 2006 | 12:21 PM
  #123
Not shorten the tranny, just driveshaft. I had mine lengthened & balanced for $100.
Old Dec 12, 2006 | 12:32 PM
  #124
wreckedj30's Avatar
No Club Love
hmm, ok then, also with ms. do i need my original chopper wheel? and what not, or should i try and use the j30's coil packs, w/o a distributor? hmm, i wonder!
Old Dec 12, 2006 | 12:36 PM
  #125
xtreme 2's Avatar
MS you can do just about anything with... have a few friends running it from my days in the Probe world... you can run coil packs with it easy...
