WreckedJ30's Z31T ecu conversion
like a circle plate inside, if you take apart yours look under neath the plate, it's there. make sure you just take it from a junk yard, cause i paid 40$ for it, and it would of taken a minute to jonk it. Just remember which side is up.
yea he did... the link is: https://www.zdriver.com/forums/280zx-performance-technical-79/z31t-ecu-swap-now-complete-19101/
Originally Posted by Bleach
you're a minor, you'll get away with that....
I soldered everthing. About 6 AFM to MAF connections, 4 or 5 ecu connections, 1 fuel pump relay connection, ground the fuel pump.
Other than that, just pop in the chopper wheel, MAF, and ecu.
Here is a Excel I put together of Z31 ecu swap info: http://home.comcast.net/~nismopick2/..._nismopick.xls
EDIT... I have a zip file of wiring diagrams at home. I will post that tonight.
ok ok ok... did some one on here make a bogus myspace for nismo619 lol.... im part of it and its kinda funny... how the gayness of it is set up.
Here is the ZIP file of the 280ZXT & Z31T ecu wiring plus the Excel spreadsheet comparing ecu pins. RIGHT CLICK & SAVE AS http://nismopick.define-touge.net/fi...u%20wiring.zip
EDIT.... for anyone that downloads this file, I forgot that I password protected the zip. The password is turbo
Originally Posted by wreckedj30
a/c lines, which, the cars pretty much stripped, it has like no amenities..haha, its cold as **** in the winter.
