more problems :(
Old Dec 14, 2006 | 11:13 PM
skittle's Avatar
Taste My Rainbow
Angry more problems :(
well i now have more problems with the car !!!! she now has no power. I drover her today and had no problem with anything minus the smoke. but i just drover her from work and she has no "get up and go". I floor the pedal and she just barely chugs along... any ideas??
Old Dec 14, 2006 | 11:37 PM
RodMoyes's Avatar
Doesn't post much...
If it comes and goes, chances are it's electrical... Probably a bad connection somewhere. Re-Check all those little connectors and contacts really well. Otherwise, it could be an intermittant problem with Coil voltage or IM, Vacuum advance... Fuel flow...
If none of that fixes it, try painting it all one color... it worked for me!
Rod.
Old Dec 15, 2006 | 05:21 AM
FubarI33t's Avatar
I had this problem. found out some how my oil pump shaft got off one notch. Quick test for this. Pull the One 10MM Dizzy adjuster bolt. Turn Dizzy in eather direction Past it's mount hole. see how she idle's when you do this. Unless you find a way (try a bolt, nut and two large washer's and sandwitch the dizzy and the mount flange together) and take her for a quick drive. This helped me. i corrected the problem. now i can't find anyone to race PPl around here think there's a V8 in it. lol. dumbass'es
Old Dec 15, 2006 | 10:15 AM
pop te hood. be like. no no... inline.. INLINE!!!!! but use a japanese accent. lol
Old Dec 15, 2006 | 10:40 AM
BoulderZ's Avatar
Last time I had those symptoms in an L-series motor it was intermittent fuel starvation being caused by an alternator intermittently going out, on it's way to a full failure. That was on an S30 L-28, though, so I don't know if the S130 L motors have the same "no alternator charge = no power to fuel pump" logic or not. Easy test: spray a can of starter fluid in the intake (a lot). If it starts and runs, and then after 5 seconds or so it dies, then there's a good chance that's the issue.
good luck, and don't give up!
Dave
ZBspires
Aug 30, 2013 07:33 AM
86z31
Aug 16, 2010 06:14 PM
turbo84z
Jan 21, 2008 02:26 PM
duowing
Sep 30, 2006 08:26 AM
hondahunter
Mar 18, 2003 02:45 AM
