A hose between Air Flow Meter and Intake Manifold, Problem?
Old May 18, 2014 | 07:08 PM
Z-Mak's Avatar
Hi,
I have 1982 280zx non-turbo for not long and I have now unstable idling problem. I look around air intake area and found one hose that is attached to the rubber duct hose between air flow meter and the intake manifold as you see in the picture. And it's end is not connected to anywhere.
Please help finding where that small hose supposed to be connected. And it is sitting on the air flow meter. It's other end has a clamp. It may be one of cause of unstable idling on the engine. And if you have any suggestion to tackle solving the idle problem, I greatly appreciate your suggestions.
Old May 19, 2014 | 07:16 AM
I believe that goes to the charcoal "evap" canister on the right side of the radiator... though it looks to short to get there. Is there an open port on the charcoal canister or anywhere else?
Also make sure you've downloaded the FSM for free as it has every diagram you'd ever need for your car. www.xenons130.com/reference.html
Old May 19, 2014 | 07:45 AM
rogerz's Avatar
Grumpy & Helpful
if nothing else at least block it off. unmetered air (vacuum leaks) are the bane of the FI engine
Old May 19, 2014 | 04:33 PM
Z-Mak's Avatar
Also make sure you've downloaded the FSM for free as it has every diagram you'd ever need for your car. XenonS130 - S130 Reference
Thank you for your quick suggestions. I did not find any nozzle on the charcoal canister or anywhere. I capped it for now.
Thank you again for those valuable links. I will familiarize myself.
Old May 19, 2014 | 04:35 PM
Z-Mak's Avatar
Thank you for your help. I capped it to see any changes. I will keep learning more on the system.
Old May 19, 2014 | 07:09 PM
PredatorZ's Avatar
Pictures
Can you pull back a bit and show the entire engine, might help identify what is missing.
Old May 19, 2014 | 07:51 PM
PredatorZ's Avatar
Valve cover
That should be able to reach the tube coming out of the side of your valve cover. In the "Engine Fuel & Emissions Control System" section of your FSM page 4 of 126 in the PDF, it clearly shows where it goes.
Old May 20, 2014 | 05:52 PM
Z-Mak's Avatar
Thank you. I will attach photos on next message.
Old May 20, 2014 | 06:50 PM
Z-Mak's Avatar
Pitures
Hi, I thank you very much that someone like you actually try to help one has problems.
First picture is from manual FSM page 4 of 126. I see a larger hose from the air flow meter goes to the valve cover. And it is not the one I have problem with small size hose from large rubber connector between the air flow meter to the intake manifold.
Size:  425.0 KB[/URL][/IMG]
And next one is the top view of the area.
[IMG][/IMG]
And next one is the hose that I can't figure out where it should be connected.
[IMG][/IMG]
This is how it looks without the hose.
[IMG][/IMG]
Finally, it is how I capped it.
Size:  128.6 KB[/URL][/IMG]
I greatly appreciate anyones' kind help. Thank you.
Old May 20, 2014 | 07:01 PM
Kevdogg's Avatar
cause none of your pics show where it goes it connects to a vacuum port its located right below thermostat housing under water temp sensor you should see it
Old May 20, 2014 | 07:15 PM
Kevdogg's Avatar
heres a pic
Attached Thumbnails A hose between Air Flow Meter and Intake Manifold, Problem?-sam_0555.jpg
Old May 20, 2014 | 10:02 PM
Z-Mak's Avatar
Originally Posted by Kevdogg
heres a pic
Thank you for quick help. I looked at it and took a picture near yours was taken.
[IMG][/IMG]
However, two small hoses are connected and not the one like yours. And there is no other nozzle is available.
TkPrez
Mar 15, 2013 09:15 PM
BigEkak1941
Feb 20, 2005 05:18 PM
Nick'75
Jun 16, 2004 03:45 PM
79bigbore280zx
Aug 27, 2003 04:57 PM
aznsensation
Jun 28, 2002 06:20 AM
