Air flow meter
Old Oct 24, 2012 | 12:23 PM
TkPrez's Avatar
Air flow meter
Quick question before i buy it
Can i put a turbo airflow meter on my na zx?
Old Oct 24, 2012 | 12:32 PM
zenzee's Avatar
Changing ECU's
What's the point though. Yes you can with all the harness and all relays etc that goes with the harness and ECU.
Old Oct 24, 2012 | 12:51 PM
IIRC the turbo and NA have a different pinout. The simple answer is no.
Old Oct 24, 2012 | 12:55 PM
You swap the guts... Shady280 and several others are running the turbo AFM with n/a guts. It's a must if you are going to do other intake upgrades (like the 60mm throttle body).
Old Mar 15, 2013 | 12:17 AM
zippy555's Avatar
AFM Bypass ?
has any one tried to bypass the AFM? make the contacts that make the ECM think its getting more or less air without using the afm?
Old Mar 15, 2013 | 04:37 AM
77280ZX's Avatar
One word, Meagasquirt. If you havnt herd of it its a stand alone ECU. Sounds like the direction your heading.
Old Mar 15, 2013 | 06:59 AM
The AFM is the EFI load sensor... every EFI system requires a load sensor of some form: AFM, MAF, MAP, A/F Distributor, etc.
Swapping to the Z31 ecu will change the AFM to MAF, which is more precise and less restrictive, or use a SAFC (Air Flow Converter) / VPC ) Vein Pressure Converter) to delete the MAF and use a MAP (more tunability options, but lots of headaches & problems).
As 77280ZX said, MS is programmed to use a MAP sensor, so that would be the best route.
If you are looking for little "tricks" to make your car faster, we've discussed many things, many times. A full tune up does wonders for a tired engine. Also, installing a potentiometer on the CHTS signal wire will "trick" the ecu into enriching the A/F mix (when set properly).
EDIT... research EFI systems (there are many books written on this topic). You can become expert very quickly.
Old Mar 15, 2013 | 09:15 PM
yes i have swapped it to the turbo one. it requires a bit of time and the hardest part is plumbing believe it or not. its a gut swap for the electronics but im changing to megasquirt for obvious reasons. it really didnt make a noticable difference to performance either, maybe on a dyno but not worth the effort unless your bored
BigEkak1941
Feb 20, 2005 05:18 PM
Zach280z78
Jul 6, 2004 08:20 AM
rinof
Nov 22, 2003 06:32 AM
79bigbore280zx
Aug 27, 2003 04:57 PM
aznsensation
Jun 28, 2002 06:20 AM
