Distributor GOO?
Old Feb 7, 2011 | 10:40 AM
BackHouseZ's Avatar
Distributor GOO?
My Car does not start..
please see pics...Is the goo stuff normal? at first i thought it was water but i touched it and it left an imprint..
Attached Thumbnails Distributor GOO?-100_1313.jpg   Distributor GOO?-100_1311.jpg   Distributor GOO?-100_1312.jpg
Old Feb 7, 2011 | 11:37 AM
yeah mine had it and it worked fine.
Old Feb 7, 2011 | 12:06 PM
rogerz's Avatar
Grumpy & Helpful
probably put in there at the factory to protect the electronics.
Old Feb 7, 2011 | 12:11 PM
BackHouseZ's Avatar
well i thought maybe i could remove it with some electronic spray cleaner but nothing..
I re installed and no change still no start.
Old Feb 7, 2011 | 02:28 PM
Indeed it's there to protect the electronics from moisture / any contaminants... it's not "goo" it's more like GLUE. It should be pretty firm to the touch... and it's there for a purpose.
Old Feb 7, 2011 | 05:55 PM
rogerz's Avatar
Grumpy & Helpful
check your ignition module and/or coil
Old Feb 9, 2011 | 08:10 PM
Yup its called potting compound. Its to keep water out of the electronics. Doesn't mean something isn't burnt out in there but it is normal "goo". You typically need to dig it out if you need to do a repair on the electronics part - it's chemical resistant for a reason
Old Feb 9, 2011 | 09:30 PM
BackHouseZ's Avatar
Finally my Car starts..I swapped out the distributor from my other z and the car started.
Now i just gotta figure why my battery is just draining.
Zdon
Aug 12, 2013 03:01 PM
cpark_12
Feb 12, 2013 06:21 PM
Fast240Z
May 20, 2005 04:18 PM
xsciuga
May 17, 2005 07:11 PM
ZmeFly
Jun 3, 2001 12:04 AM
