Parking lot cruise... with no battery?
Old Sep 26, 2007 | 08:34 PM
rxKaffee's Avatar
Parking lot cruise... with no xxxx?
I know some race cars run with no battery, but I'm sure they have a higher output alternator. My battery ground had came loose a coulpe times while driving and everything sputtered very poorly, but it didn't completely die.
So what I'm wondering is... If I get the car jump started with no battery in it(hook jumper cables to the Z's battery cables?), will the alternator provide enough juice to the injectors, ignition, etc. to cruise the car down to the other side of my parkinglot?
I could drop the battery in my Z from the car I'd be jump starting it with, but its got GM style sideposts that I don't think my Z's standard battery cables will be a good enough fit to do much.
Thanks guys, rx
Last edited by rxKaffee; Jun 25, 2008 at 01:12 PM. Reason: Resurected for generaliztion.
Old Sep 26, 2007 | 08:36 PM
You need to know the basics of an electrical circuit.... in a car the electricity needs a complete path from + to -. Without a battery, the electronics won't work, because there is no complete path. Maybe a carb'd motor could run by itself using an alternator to charge the coil... but an efi system needs power.
Old Sep 26, 2007 | 08:45 PM
rxKaffee's Avatar
I'm not completely in-the-know on how an alternator works, but I assume its something like a DC motor? A standard DC motor can be driven(instead of given electrical power) to produce both a + and - paths to power a small light.
Is the problem that our alternator not provide us with a path for the -?
Old Sep 27, 2007 | 06:26 AM
PooFlinginMonke's Avatar
Be prepared for 18+ volts killing anything electronic.
Old Sep 27, 2007 | 10:04 AM
ummm... i tihnk its the other way around, some drag cars dont use alternators.... never heard of no battery cars though.
Old Sep 27, 2007 | 10:16 AM
That's what I was thinking too. It doesn't make sense to remove the battery... but removing the alternator might benefit a lil if the motor is built for high rpms (higher than what the alt is rated to).
Old Jun 25, 2008 | 01:18 PM
rxKaffee's Avatar
with no alternator or airflow meter...
So this time around, I have a good battery. I'm again wanting to just crank the car up and run for couple minutes, not "going" anywhere. What I'm missing now is an alternator and airflow meter. I'm assuming the ecu will go into a sensorless static fuel map with the afm missing, but can things be expected to run right with the alternator out? Yes this means I also have no belt spinning my water pump. I think this shouldn't be much of an issue if I keep the rpms low and don't run long enough to heatup. Please correct me if I'm wrong.
Thanks, rx
Old Jun 25, 2008 | 01:47 PM
280zx2by2's Avatar
Haterade by da gallon!
problem is when you get too much voltage... the battery stores it and supplies it at a reasonably constant voltage... so if you just hook up the alternator and you slow down and the alternator isnt spinning fast enough then the cars gonna die!!!
Old Jun 25, 2008 | 01:49 PM
The car won't start w/o an AFM.
Old Jun 25, 2008 | 02:40 PM
lifegrddude's Avatar
Externally Wastegated
You can run a car without a battery provided you crank it up first with a battery hooked up. Just don't do it for a prolonged period of time. Don't worry about voltage.... The voltage regulator takes care of that in the alternator. And as Nismo said, no AFM, no start. Make sure you have the water pump hooked up, or that you only run the engine for a minute or two at the longest. L motors love to pop a HG once you hit high temps.
Old Jun 27, 2008 | 12:22 PM
JavaJiver's Avatar
Is there a reason you cannot push it?
Old Jun 27, 2008 | 02:39 PM
Niku-Sama's Avatar
eff good grammar
what about early early cars that you had to start with a crank in the front?
Old Jun 27, 2008 | 03:37 PM
that would be because they didnt have a starter no electrical system only a self sustained magneto ignition system like a lawn mower. thats a really stupid comment. sit down thanks
Old Jun 27, 2008 | 03:48 PM
280zx2by2's Avatar
bleach's fairlady dosen't have a battery!!! thats why it dosen't start!!!
Old Jun 27, 2008 | 11:07 PM
Niku-Sama's Avatar
eff good grammar
yea your only bein like that because i thought of it and made you look dumb.
noob, 20 posts pshh
Old Jun 29, 2008 | 12:00 AM
technically, its still almost a type of alternator. actually. if i remember watching i love lucy they had a crank type car once when it broke down out in the desert and they had a radio going before, so for all i know they do have a primitive alternator. you cant prove they didnt.
z-hag
Apr 21, 2007 07:34 PM
mark86t
Jan 30, 2007 10:11 AM
Zrolimit
Apr 26, 2006 12:16 AM
JohannB
Apr 22, 2005 12:51 PM
alex
Oct 18, 2004 05:06 AM
