i cant start my car!!!
Old Nov 17, 2010 | 01:05 AM
street demon's Avatar
Question i cant start my car!!!
a while back u guys had helped me with my oil not flowing n well it flows now but ever since i priemed it i haven't been able to turn on the car..it cranks but just wont start, can i have some help? cuz i miss driving my "z"its a 280zx ,just rebuild n made turbo
Last edited by street demon; Nov 17, 2010 at 01:10 AM. Reason: i 4fot to put what kind of car i had..lol
Old Nov 17, 2010 | 02:19 AM
We would need some more information on it. It could be timing, or a fuel, air, or spark problem. When mine didn't start, after running on starter fluid for few seconds. It turned out to be my timing. I was off just one tooth. And it wouldn't stay running.
So you did a Turbo conversion? Then it could be many things. I am sorry I can't help you there. You will need Turbo gurus, to help you out. Good luck man.
Old Nov 17, 2010 | 06:55 AM
Do you have spark? Are the injectors spraying?
Old Nov 17, 2010 | 02:03 PM
yea i have spark n the injectors should b spraying they r new...i think i mest up the timing cuz i took of the distributer n when i put it back it wouldnt turn on
Old Nov 17, 2010 | 02:55 PM
Just the distributor? Make sure you have it securely in place. You may not have it on the shaft enough. You can only put it on one way. It has a notch in it. Do a test, and take the cap off. And see if the rotor spins. If it doesn't, that means your distributor, is not all the way on.
Old Nov 17, 2010 | 05:57 PM
yea just the distributor .. ama check that out n see what happens then.. hopefully its that..
Old Nov 18, 2010 | 10:44 PM
ok i took off the distributor cap n the rotor does spin so it is all the way in..it souns like it wants to turn on but it just doesn't u think the timing got out off place or something...????
Old Nov 19, 2010 | 06:42 PM
anyone that has an idea on what it is pls let me know ..i cant figure it out..anything will b usefull to me thanx!!
Old Nov 19, 2010 | 07:14 PM
Oh, I overlooked something in your first post. Yeah I bet you have the timing off on the engine itself. I'm afraid you might have to take the timing cover back off. I did a writeup in another thread, if it will help you. Good luck man. Sorry for overlooking your post.
https://www.zdriver.com/forums/fs-240z-260z-280z-280zx-70-83-242/water-leaking-timing-cover-31579/
Old Nov 19, 2010 | 08:23 PM
ok thanx wildman ama give that a try then n ill let u know how that goes...
Old Nov 19, 2010 | 10:56 PM
No problem man. Sorry I didn't catch it sooner.
zcooks
Apr 11, 2016 06:36 AM
bongpogi
Aug 19, 2015 11:15 AM
moorebl
Apr 14, 2011 03:28 PM
bardabe
Sep 21, 2004 03:12 PM
