My Z won;t start
My Z won;t start
ok I bought a Z I'm a new bee It's a 90 nonturbo Manual My belts where squeaking when I turned on the car. so I decided to leave the car on and spray some WD-40 o the belts while it was on when I got back on the car to move it back to the parking spot it stalled on me and it died completly well almost nothing works exept for my high beams everithing else is dead what is wrong with my car? I need help
Odd that only the high beams work. Nothing else?!? No cabin lights, no radio, no clock,...nothing? When you try to start it, does it turn over at all? if not, can you hear the starter solenoid click?
WD-40 isn't for belts. Whoever told you to do that, please slap them. If you thought of it on your own, please slap yourself. Squealing belts will stop squealing by using WD-40, but it's not fixing the problem. Go to your local auto parts store and pick up a belt dressing. You may need to spray a degreaser on the belts to remove the WD-40. If not, then it will attract more dirt and it will cause thhem to squeal worse.
when only your high beams work that means there is some kind of short in your system. Check your fusible links, and your fuses. as far as belt noise goes get some belt dressing or roll your sleeves up and tighten them up
*Note*
uhh? where's the fuse box inside the car cause I know there are 2 under the hood 1 by my battery and one by my left headlight but there has to e one insidwe the car where is it?
the fuse box is under the footrest on the left side of the driver side. there should be some screws in the very back left, on the plastic cover, and some on the plastic railing on the bottom of the door sill to take out.
YEAY!!! My bro Fixed my ignition problem it's now back to it's old self now I juts have to replace my ignition coil harness and I thing some valves on Piston 1 cause @ 2000 RMP it does a ratteling noice but Exavly 2000 if I go further it stops if I go Under it stops what U guy's think?
Your ears.
You just need to listen for it. With the engine running, listen to different places in the engine compartment. Once you've located the area where the noise is coming from, try applying pressure to different surfaces. You may be able to find what came loose, or what is rubbing where it shouldn't be.
Ok I think it's my valve springs HAve U ever changed thenm or gotten them adjusted on ure 300 and what is a fair price to get them adjusted and a fair prize to get em replaced so U know?
What makes you think it's the valve springs? Valve springs don't make any noise. A valve spring is just a spring that closes an intake or exhaust valve. You don't adjust valves in these cars. It's a major job to change the valves and the springs. I've never changed them and never heard of anyone needing to have them changed unless they snapped a timing belt. I've never even seen a write-up on how you're supposed to do it. You said that you only hear it at 2000 RPM. It it was a valve issue, you'd most likely hear it at higher RPM's.
well I took it 2day he said that there is something rubbing 2gether and he'll check if not it's just my lifters are loose but he doubts that he says it's most like ly something rubbing
bongpogi
Aug 19, 2015 11:15 AM
moorebl
Apr 14, 2011 03:28 PM
