How much slack should the timing chain have?
Old Apr 17, 2010 | 12:09 AM
Sixer's Avatar
While making a failed attempt at adjusting the valves, I noticed that the timing chain isn't super tight. It has probably a 1/2 inch of play when I put tension on it. Is that too much?
Old Apr 17, 2010 | 02:46 AM
Cali79zx's Avatar
When I put my chain on it had about the same amount of slack. So I'm gonna say it should be fine.
Old Apr 17, 2010 | 08:37 AM
There should be NONE, ZERO, NADA, NO slack. When you re-install the timing chain, you are supposed to push the chain guides in while tightening. I actually use big wood clamps to keep them all the way in while I tighten them down.
Old Apr 17, 2010 | 11:08 PM
Cali79zx's Avatar
lol I honestly never did that. When I set the chain and tensioner on I had about the same slack and I just took the timing cover off today and the slack is gone. I never messed with the guides either
Old Apr 18, 2010 | 07:00 AM
FubarI33t's Avatar
the tensioner kicked in once you started it. tightened it up.
Old Apr 19, 2010 | 10:01 PM
Duck Ryder's Avatar
Interesting, I just pulled my valve cover off today and noticed the slack in the chain. Figured I would just replace it considering the current predicament my car is in...
Old Apr 25, 2010 | 08:53 AM
ToxicZ's Avatar
No slack indeed, the chain tensioner can pick up but if the chain is blocked when the cam wheel is taken off getting it back on should be a tight maneuver
Old May 22, 2010 | 09:10 AM
PooFlinginMonke's Avatar
Since the tensioner is only spring loaded, it will allow the chain to slacken when the engine is turned backwards a couple of degrees.....which happens about 50% of the time during shutdown.
On cars with high mileage, you can hear the chain hit something as it goes backwards from compression while you bump the engine to adjust the valves.
Old Apr 7, 2011 | 11:26 AM
zstuff's Avatar
timing chain
one side of the timing chain should be tight like your 1st girlfriend and the other side has the same tension onless you manually turned the crankshaft the wrong way while adjusting valves
Switchtr3
Sep 16, 2011 09:01 PM
280zx2by2
Mar 14, 2010 09:41 AM
Bleach
Oct 14, 2005 06:38 PM
280zExTURBO
Oct 12, 2005 03:19 AM
mck2
Sep 5, 2002 07:29 PM
