Heater control valve
Old 05-30-2012, 03:24 PM
ambiance4vr's Avatar
I have a 1982 280ZX that needs a new heater control valve. It origionallt called for part #27116-P7100 but was redesigned and now goes by part #27116-P6500. What I want to know is what modifications and / or changes need to be made as the two parts are not very similiar?
ambiance4vr is offline
Old 05-30-2012, 09:33 PM
Do you have auto or manual climate controls?
I know one of the valves had a thermo coil that ran to the heater core box, and later replacement versions didn't include it (no side effects).
Discussed here:
https://www.zdriver.com/forums/280zx...roblems-22982/
and
https://www.zdriver.com/forums/280zx...6-p7100-28580/
NismoPick is offline
Old 05-31-2012, 08:39 AM
It is a manual. The old one has the coil. The new one does not. My question is what needs to modified to make the newer version fit and work properly.
Old 05-31-2012, 08:51 AM
Hopefully you clicked those links I posted?
Originally Posted by icice9
yup got it to work... i had to cut the coil off the old choke valve cuz i didnt know how to remove it from the heater. the mounting screw were in diffrent locations but it still mounted right... i had to adjust the cable and push/ pull pins but all in all the new choke works just fine...
Old 06-25-2018, 06:49 AM
AlishaA1959's Avatar
I have manual controls with factory air conditioning
AlishaA1959 is offline
CWHammer
02-17-2010 04:38 PM
Speedwrench
06-02-2009 12:43 PM
lts70
05-06-2009 01:18 PM
WillbeWild79
04-30-2005 12:14 PM
mattduskater
04-05-2005 10:37 PM
Quick Reply: Heater control valve
