Heater control valve
Old May 30, 2012 | 03:24 PM
ambiance4vr's Avatar
I have a 1982 280ZX that needs a new heater control valve. It origionallt called for part #27116-P7100 but was redesigned and now goes by part #27116-P6500. What I want to know is what modifications and / or changes need to be made as the two parts are not very similiar?
Old May 30, 2012 | 09:33 PM
Do you have auto or manual climate controls?
I know one of the valves had a thermo coil that ran to the heater core box, and later replacement versions didn't include it (no side effects).
Discussed here:
https://www.zdriver.com/forums/280zx...roblems-22982/
and
https://www.zdriver.com/forums/280zx...6-p7100-28580/
Old May 31, 2012 | 08:39 AM
It is a manual. The old one has the coil. The new one does not. My question is what needs to modified to make the newer version fit and work properly.
Old May 31, 2012 | 08:51 AM
Hopefully you clicked those links I posted?
Originally Posted by icice9
yup got it to work... i had to cut the coil off the old choke valve cuz i didnt know how to remove it from the heater. the mounting screw were in diffrent locations but it still mounted right... i had to adjust the cable and push/ pull pins but all in all the new choke works just fine...
Old Jun 25, 2018 | 06:49 AM
AlishaA1959's Avatar
I have manual controls with factory air conditioning
CWHammer
Feb 17, 2010 04:38 PM
Speedwrench
Jun 2, 2009 12:43 PM
lts70
May 6, 2009 01:18 PM
WillbeWild79
Apr 30, 2005 12:14 PM
mattduskater
Apr 5, 2005 10:37 PM
