Heater control valve
I have a 1982 280ZX that needs a new heater control valve. It origionallt called for part #27116-P7100 but was redesigned and now goes by part #27116-P6500. What I want to know is what modifications and / or changes need to be made as the two parts are not very similiar?
Do you have auto or manual climate controls?
I know one of the valves had a thermo coil that ran to the heater core box, and later replacement versions didn't include it (no side effects). Discussed here: https://www.zdriver.com/forums/280zx...roblems-22982/ and https://www.zdriver.com/forums/280zx...6-p7100-28580/ |
It is a manual. The old one has the coil. The new one does not. My question is what needs to modified to make the newer version fit and work properly.
Hopefully you clicked those links I posted? :paranoid:
Originally Posted by icice9
(Post 268586)
yup got it to work... i had to cut the coil off the old choke valve cuz i didnt know how to remove it from the heater. the mounting screw were in diffrent locations but it still mounted right... i had to adjust the cable and push/ pull pins but all in all the new choke works just fine...
I have manual controls with factory air conditioning |
