Rear end Noise
Old Mar 22, 2013 | 02:13 PM
Zkelmhd's Avatar
Rear end Noise
OK heres whats going on. The previous owner had the stock r200 go bad on him and he had a r180 sittin around so he stuck that in there .. He mentioned something about its rubbing on the body somewhere and it just needs a spacer installed. It makes noise .. noticabe at 40 loud at 60. The way he described it there is a plate under the carpet that needs to be pulled out and i will understand exactly whats going on .. anyone know what he means .. Im pullin a dummy card on this one .. im lost. i think i found the plate but i cant get up .. and i cant find anything in the service manual .. ADVICE PLEASE
Old Mar 23, 2013 | 08:24 PM
Originally Posted by Zkelmhd
It makes noise
Perhaps you could be a bit more specific about the "noise" ? What does the noise sound like?
Yep. Click: XenonS130 - Free FSM Downloads
Also click: Nissan OEM Diagrams - 280ZX rear axle
Old Mar 25, 2013 | 08:04 AM
Zkelmhd's Avatar
alright i suppose i should have been more descriptive. its like a fine grinding sound.. not like a bearing and not rear end wine. he thought that something may be grinding on the body... that #1 in the diagram is the place under the carpet.
so from what i understand the rubber spacer or bushing whatever you want to call it #11 is not installed because it is not the same on the r180 is that correct ?
Old Mar 26, 2013 | 09:01 AM
yeah he prolly never installed the correct #11 part. the #1 part can also be turned around to swap its position for the different diff combos. or he never installed #6. only one way to tell is crawl underneath and take some pix
Old Mar 28, 2013 | 01:34 PM
Zkelmhd's Avatar
ok thats starting to make some sense he was talking about turning #1 180 and then installing the other part .. thanks a ton .. if i still cant figure it out ill shoot some pics
Punchiest
Aug 9, 2013 01:09 PM
Z_lover
Aug 13, 2007 04:30 PM
ShadyJ
May 7, 2005 02:47 PM
JohannB
Oct 24, 2004 07:12 AM
SwiggA88zxt
Apr 21, 2002 10:57 AM
