wiring problem
Old Oct 25, 2005 | 07:55 PM
Turbo280Z's Avatar
wiring problem
Ok here's the deal. I have a 78' 280z when I got it it had a drawthrew turbo weber setup. I'm currently trying to put the fuel injection back in. I have a motor from a 82 280zx turbo and the efi harness. There's power at the computer but I can't get the rest of the efi system to work. I've had a few ppl take a look at it and no one can get the coil to work at all. does anyone know what I should do? Or have any knowledgable information? Do they make a after market efi harness that's easier to use?
Old Oct 25, 2005 | 08:02 PM
so have you checked the volts going to the coil?
Old Oct 25, 2005 | 10:03 PM
Turbo280Z's Avatar
I don't have the wires going to the coil. I need to re run the wiring for it.
Old Oct 25, 2005 | 10:45 PM
I think that's why the coil won't work then!
Old Oct 26, 2005 | 02:36 PM
Turbo280Z's Avatar
Well obviously. I'm trying to find a way to run the wiring but I can't seem to find a detailed diagram of the efi wiring. Do u know where I can find one? Or the easyiest way to run the efi?
Old Oct 26, 2005 | 03:07 PM
Turbo280Z's Avatar
Old Oct 26, 2005 | 09:53 PM
Buy a Haynes or Chilton repair manual & trace the wires. Repair books are wonderful!
Old Oct 27, 2005 | 10:14 PM
Turbo280Z's Avatar
I have them they suck. I can get the 78 stock harness all complete for 150 I'm prolly gona get it and see if I can put the turbo harness in with it or if the ecu will jus clip in.
Old Oct 28, 2005 | 06:59 AM
interesting.... all those thousands of mechanics must be stupid for using them huh?
Old Oct 28, 2005 | 07:01 AM
$150? somebody is trying to rape you.... also, good luck w/ spicing together a turbo & n/a harness... (the turbo & n/a ECU's are very different)
Old Oct 28, 2005 | 09:40 AM
Turbo280Z's Avatar
Well its not that they suck there jus not detailed enough. And its 150 for the harness and there taking it out its 100 if I do it and its the entire harness. I have the turbo efi harness jus need to put them together
ellisdaddy917
Mar 17, 2009 09:09 PM
jaredjmoore89
15
Dec 19, 2008 11:08 PM
swmoman
Apr 2, 2005 04:47 PM
FoxZ31
Mar 27, 2005 02:18 PM
southern280zx
Mar 2, 2005 09:46 PM
