Need help or walk through on how to replace fuel injectors on my 77 280Z
Old Nov 22, 2011 | 12:27 AM
armanzz's Avatar
Im working on my 77 280z and am having a problem replacing the fuel injectors. I am mainly having a problem releasing the fuel pressure in order to be able to take off the fuel rail and etc. If anyone has a write up on how to replace the fuel injectors on my z, I would really appreciate it. Thanks alot.
Old Nov 22, 2011 | 11:07 AM
Welcome to ZDriver!
If you haven't bought a Haynes manual yet, I suggest doing so. Or download the FSM from www.xenons30.com/reference
To release the fuel pressure, you can just yank the fuel line off & let it spray out, or remove the fuel pump relay / disconnect the fuel pump connector & crank the car for a few seconds.
Old Nov 22, 2011 | 11:32 AM
Bates's Avatar
^ This. A 280Z fuel rail is the easiest thing to work on since it is right up top with nothing in the way. I would pull the fuel pump fuse, turn the car on and let it die, which should only take a second or two, then pull a hose off something like the fuel filter just to get any other pressure released and then start unbolting the fuel rail and start popping out the injectors. Each injector will have 2 screws holding it in. I hope you are replacing all the O-rings on the injectors if you are taking them off, I am sure they are pretty old regardless.
BozZ
Aug 19, 2012 03:34 PM
zunasec
Mar 2, 2011 04:32 PM
TeamRonin
Oct 6, 2009 10:24 PM
wr-ecks
Nov 10, 2008 07:46 AM
NismoPick
Oct 1, 2007 09:30 PM
