a little rant
Old Oct 31, 2008 | 05:34 PM
260zturbo's Avatar
Stupid Hurricanes...
a little rant
i got one of my packages in today but needless to say part of it was broke. i had insurance on the package but it seems the package company does not want to do anything about it.
anyway its a triple weber 40mm turbo blow through. my plans are to convert these to efi and fix the plenum
Old Oct 31, 2008 | 07:17 PM
KasbeKZ's Avatar
Pr0n Addict
what do you mean convert webers to EFI?
Old Oct 31, 2008 | 07:31 PM
convert them to ITB's its pretty popular but most people just use the manifolds and adapt new real ITB's to them so you could go that route but still alot of money i bet was spent on the full setup
Old Oct 31, 2008 | 07:40 PM
KasbeKZ's Avatar
Pr0n Addict
yeah i bet too. i've seen a used set of triple side drafts go for $2k.
but that sucks about the breakage. is it something you could patch up with some jb weld?
Old Nov 1, 2008 | 07:49 AM
is it extrude a body or something like that that everyone uses for good itb's ? i think thats the company sounds right. just go with that route it will be kick *** looking and you can make a clear plexiglass/lexan box to seal them in since your turbo to so you can see those beautiful motherfawkers and they arent covered up by a non transparent box
Old Nov 1, 2008 | 08:41 AM
260zturbo's Avatar
i dont know much about the parts if a weber but it seems to part of the choke or float valve. anyway im most likely going to unscrew those parts off and put a bloke plate in. yes u can convert these to efi by gutting a smale part and welding in some injector bungs. the whole setup was 500 the setup has fresh gaskets so i cant complain to much.
Old Nov 1, 2008 | 11:49 AM
ASA240z's Avatar
ダットサンマニアック
what type of FI do people use when they do that?
Old Nov 1, 2008 | 05:30 PM
260zturbo's Avatar
i have megasquirt to do my fuel injection as well as many other things. if thats what you are asking. efi=electronic fuel injection, fi=forced induction in most cases ex turbo
Old Nov 1, 2008 | 05:51 PM
technically... you can use any EFI system on ITB's as long as you can adapt the stock parts to fit aka injectors throttle cable and TPS thats it really. in a nut shell anyways. for us we would also need a way to adapt the AFM to them and hopefully no idle issues are created since so many other emissions devices are removed, but you can use any you want. however, they would be deemed pointless without a standalone fuel system and honestly any decent standalone will do just fine
Old Nov 1, 2008 | 08:05 PM
260zturbo's Avatar
the tps is going to be easy already figured that out. injectors bungs are going to be pretty easy just drill and tig them in. with ms u dont need the afm because u have a air intake sensor. i might have to fab up a fuel rail or see if i can use my pallnet one. but these have idle control srews so thats going to be easy to set up. this is not a pratical setup by all means. just doing it for the hell and want to see some nice numbers. megasquirt is going to control everything as its doing now. i have to convert back to linkage setup so i had to dig up my linkage setup and pull out a spare gas pedal.
Old Nov 1, 2008 | 11:33 PM
i know i know... i was answering the question what kind of EFI do you need and i said you COULD use stock thats why i mentioned the AFM. i loosely use the word could though because it would be tough could run into some problems with idle and such and would be kinda worthless.
Bruce_Aldridge
Oct 22, 2014 01:50 PM
captken
Aug 22, 2009 06:33 PM
NismoPick
Apr 2, 2009 12:22 AM
HybridS130
May 14, 2005 01:45 PM
z432
Feb 15, 2002 11:51 PM
