Won't Start
Old Apr 18, 2006 | 07:43 PM
1stz32's Avatar
Won't Start
I just recently bought a 1990 300zx from a buddy of mine, been driving it a about week and ran great. Poped the hood today to check the air filters, found out there were K&N, looked a little bit dirty so iwashed them and put them back in, put everything back together and the car wouldn't start. Thought it was kinda odd that changing/cleaning the filters would cause that sort of problem, so i called my buddy and he said that we had a problem once in a while with the battery going dead on him would roll over but not start. So i hooked up a charger charged it and it read 13 volts with the key off. Again will roll over but not start. Checked all connecters to make sure i didn't dissconnect something buy mistake. Can anyone give me an idea of where i should start to solve my problem?
Old Apr 18, 2006 | 08:03 PM
If it won't start, it's 1 or 2 things:
-No fuel
-No spark
(in this case, the ecu is prolly not getting a signal from a major sensor & not allowing spark)
Now you need to find out why...
Was the car running before you took off the filter? If so, you've missed reconnecting something. Do a double check on all the connections.
Old Apr 18, 2006 | 09:03 PM
japanz's Avatar
PTU or CAS but I will say you need to run the codes and get the results from there. Could be a number of things but you should always try to run your codes first, then check and clean any connections second and then if you still can't figure it out then you get nervous.
Yep, that is about it!
Old Apr 19, 2006 | 06:17 AM
1stz32's Avatar
Do you know where i can get ahold of a code scanner, is it an OBD 1 or 2?
Old Apr 19, 2006 | 08:32 AM
japanz's Avatar
Yeah...I can sell you one for about $50 and it comes with a bridge. Just send the money to...
Kidding, you can do it yourself by clicking here:
http://zhome.com/ZCMnL/PICS/ecu/ecu.html
Old Apr 19, 2006 | 07:45 PM
1stz32's Avatar
Thanks
Just wanted to say thats for your help, ran the codes camed up 55 (none recorded.) But I did find the problem it was the wiring running to the power transistor... that seams to be a comon problem. Anyone know if of another fix besides buying a new one ($180) or soldering the connections?
Old Apr 20, 2006 | 05:37 AM
japanz's Avatar
First check if you have the old style or the new style. If you have the old style then go to the dealer and get a free replacement for the recall.
Old Apr 20, 2006 | 12:33 PM
1stz32's Avatar
new style...
Old Apr 24, 2006 | 08:51 PM
91zxtt's Avatar
Did you disconnect the MAF when you cleaned the filter? Did you remember to plug it back in?
zcooks
Apr 11, 2016 06:36 AM
bongpogi
Aug 19, 2015 11:15 AM
moorebl
Apr 14, 2011 03:28 PM
bardabe
Sep 21, 2004 03:12 PM
