some clutch issues
Old 06-06-2009, 07:08 AM
z32Burns's Avatar
some clutch issues
I've got a slight problem right now.. my clutch had went out on me before i came back to iraq, so i ordered a spec clutch and flywheel for replacement. the 2 parts are for the 90 n/a.. i had it all put in by my mechanic and it all goes good, up until you try and give it alot of power, then it seems to slip. would the spec clutch and flywheel not be a good combo for everything else being stock and i should have just gone with the original parts or what. also im pretty sure the synchros are bad cause its grinding when i go into 2nd when i get on it, but if i relax and shift then theres nothing. any ideas?
z32Burns is offline
Old 06-09-2009, 04:26 AM
Pr0n Addict
KasbeKZ's Avatar
your mechanic probably got oil or grease on the friction surfaces.
what do you mean by spec? you mean aftermarket or OEM?
KasbeKZ is offline
Old 06-09-2009, 02:41 PM
z32Burns's Avatar
ok ill check into that..
and by Spec, i was pertaining to the aftermarket brand
z32Burns is offline
jr84'300zx
12-23-2013 07:47 AM
7d82adz
07-05-2013 06:09 PM
SwitchAZ
06-04-2012 01:35 PM
Wishihadahonda
12-07-2009 11:27 PM
colin_barnes
07-23-2006 08:58 PM
Quick Reply: some clutch issues
