240z Clutch issues
Old Mar 10, 2012 | 02:52 PM
SwitchAZ's Avatar
240z Clutch issues
Have a 73 240z clutch is giving me a hard time. Master cylinder in good shape, replaced slave and flushed out system, but clutch still isnt doing anything. Any ideas on how to fix this without having to drop transmission?
Old Mar 21, 2012 | 01:55 AM
ChEng's Avatar
What do you mean by "the clutch still isn't doing anything"? This is a little too vague to be of any use in diagnosing the problem.
Old May 5, 2012 | 08:02 PM
SwitchAZ's Avatar
slave cylinder is all the way out but is just sitting on fork.
Old May 5, 2012 | 08:03 PM
SwitchAZ's Avatar
transmission is down, is a brand new clutch. lengths for rods are perfect. Not sure why wont disengage.
Old May 6, 2012 | 02:46 PM
theramz's Avatar
I have a present for you...
Make sure you bleed the master and then the slave. Did you put the clutch and tranny in? It could also be that the fork is not on the pivot.
Old May 7, 2012 | 09:00 PM
SwitchAZ's Avatar
master and slave were bled. Fluid running through. Possible master dried out?
no clutch seems to be replaced before i got the car, but very recent. seems to be original tranny. Gears run fine from what i could do without a clutch.
Fork seems to be fine. Going to lift tranny back in once done with floor pans.
Old May 7, 2012 | 09:14 PM
theramz's Avatar
So the PO put the clutch in? And it worked after you got it?
If you watch the fork movement when the pedal is depressed does it have sufficient travel?
Old May 7, 2012 | 09:21 PM
SwitchAZ's Avatar
When pedal is pushed i get nothing. The slave bar is all the way out and so wont give the fork any movement. Fluid is getting to slave, it has to be the length of the bar or something with the fork angle im guessing? im not sure. everything is reading out that it should work just fine.
Old May 7, 2012 | 09:27 PM
theramz's Avatar
Who put the clutch in? Who put the tranny in? Who bled the lines?
Old May 7, 2012 | 09:32 PM
SwitchAZ's Avatar
clutch was previous owner, so was most likely last to remount tranny. Is correct clutch. i bled lines, and will be remounting clutch again personally. only thing missing in bell housing is the fork boot.
Old Jun 4, 2012 | 01:35 PM
chaztg's Avatar
It's the throwout bearing collar, it's from a ZX & it's too short so the bearing's not pressing on the clutch fingers even when the pedal is fully depressed. You may need to drop the trans agin to verify clearance & travel of the the release fork & bearing/collar assy. It sucks. Good luck
jr84'300zx
Dec 23, 2013 07:47 AM
7d82adz
Jul 5, 2013 06:09 PM
Wishihadahonda
Dec 7, 2009 11:27 PM
z32Burns
Jun 9, 2009 02:41 PM
colin_barnes
Jul 23, 2006 08:58 PM
