oil pump
Old Aug 24, 2015 | 10:20 PM
Steve Beddoe's Avatar
oil pump
I was wondering how likely is it for an oil pump to fail on a 1990 TT. Reason is my oil pressure gage is not working. Im going to have an external gauge put in. If the oil pump is failing what are the signs?
Old Aug 25, 2015 | 07:25 AM
The usual culprit is a dead oil pressure switch / sending unit. If it's truly not getting oil pressure, the engine will make quite a racket.
Old Aug 25, 2015 | 10:05 AM
rogerz's Avatar
Grumpy & Helpful
oil pumps rarely fail. they deliver a fairly constant flow of oil to the system. They are gear pumps constantly lubricated by the fluid they deliver. as bearings wear your pressure falls even tho the pump is delivering the same flow. likely a sensor fairly as stated above.
sameerb1
Mar 20, 2011 05:21 AM
murrayc83
Feb 1, 2007 12:22 PM
ern
Oct 20, 2006 07:01 AM
Andross
Mar 17, 2006 07:09 PM
280ZXtreme
Apr 10, 2001 07:00 AM
