O2 Sensor
Old Feb 27, 2006 | 09:50 PM
MO1's Avatar
MO1
O2 Sensor
Hey Z People:
Glad To Meet Ya. Some Of My Wiring Is Going Bad On 90 Tt. The O2 Sensor On The Harness Side Has Busted Wiring. Any Suggestions On Reparing Other Than Going To A Junk Yard? Also Any Tips On Removing The Passg Side Sensor. At Least I Can See It. Thanks
Old Feb 27, 2006 | 10:06 PM
jfairladyz's Avatar
How are you with soldering and a heat gun? That's all it should take to replace the bad wiring. If it's the connector itself that busted then you can pick up a generic connector set from an autoparts store and solder that in place of the original connectors.
Old Feb 28, 2006 | 09:26 PM
MO1's Avatar
MO1
Thanks, I Appreciate The Response. So Any Three Prong Conector Will Do? I Can Use A Heat Gun. Also, What's The Trick To Remove The Whole Sensor, If Needed. I Bought A 11/16 Socket But Too Big. Thanks Mo
Old Feb 28, 2006 | 10:06 PM
jfairladyz's Avatar
You can pick up a o2 senser socket at any autoparts store. If you dont feel like purchasing one then Autozone will loan you one. It's free but you have to leave a deposit. It's got a slit down the side so the socked fits right over the sensor and allows the wire to go out the side so it's not in the way. Or if you have a cut off tool you can make your own. I'm not sure what size the o2 sensors are on the Z32 though. As far as the connector goes, yeah. Anything will work as long as both side match up and it connects all the wires to the right wires.
nick731
May 8, 2012 07:38 AM
jaredjmoore89
Nov 29, 2008 08:09 PM
thxone
Jun 18, 2006 04:29 PM
n00blar
May 13, 2006 05:47 PM
Seraphic
15
Jul 13, 2005 09:22 PM
