new problem
Old 02-13-2005, 08:28 PM
allmotor300z's Avatar
new problem
after i adjusted my timing on my car beacuse of my ticking valves it worked ok for a couple of days an then somtimes my car wouldnt start so i had to push start it no when i barley tap the gas instead of the rpm's going up they drop down briefly what could this be?
allmotor300z is offline
Old 02-14-2005, 06:12 AM
Jack Of All Trades
CanyonCarver's Avatar
We should assume that your "ticking valves" was actually detonation since you figured that adjusting your timing would fix the problem?
If your engine bogs or wants to die when you press on the gas, the first things to check for would be vaccum leaks and/or your timing being way off.
CanyonCarver is offline
Old 02-14-2005, 07:51 AM
El Viejo
Zgringo's Avatar
Right on CC. Sounds like someone has been doing some adjusting and not getting it to factory specs.
Zgringo is offline
Old 02-17-2005, 05:35 AM
no i have the timing at factory specs but sometimes it just wont satret and the i will run the codes on the ecu and it will say 34 dentiotnation sensor then it wil go away to 55 system ok so cant figure out the problem
Old 02-17-2005, 06:25 AM
Jack Of All Trades
Sounds like a intermittent problem ....... Have you cleaned all of your electrical connections in that area? Verified that there are no loose connections? maybe do a continuity check on the wires. The copper inside can break down even when the outside looks o,k.
Old 02-17-2005, 07:56 PM
91zxtt's Avatar
Cross your fingers that it's not the detonation sensor. That's not fun to replace.
91zxtt is offline
Old 03-22-2005, 09:47 PM
RuZZeLL's Avatar
When I replaced my fuel injector plugs the wires were a little green on the inside, even way inside the wiring harness. Is that consistent with the wire breaking down? I hope I don't need the full $350 EFI harness. I could test the resistance from each end of the wire, huh...?
RuZZeLL is offline
Old 03-23-2005, 06:09 AM
Jack Of All Trades
Yes
.....I could test the resistance from each end of the wire, huh...?
Yes
You could even replace individual wires if you chose too, as opposed to buying a new harness
Old 03-23-2005, 07:09 PM
WhtFairLadyZ's Avatar
That little green crap your talking about RuZZel is actually corosion. My TT wiring harness is eat up with it. So i m waitin til i do my motor swap to change it out.
WhtFairLadyZ is offline
Old 03-23-2005, 11:15 PM
RuZZeLL's Avatar
I've been studying my FSM most of the day- just learned that you can trace the wires from each sensor/connector/etc that is important under the hood to a pin on the ECU harness connector. SO, if you suspect corrosion as a culprit in some engine issues, just test each end of the line and see if you have full continuity. Cool beans.
Blink, Ruzzell, BLINK! Agh! It burns!
RuZZeLL is offline
Myzsucksass
11-28-2013 06:58 AM
turbo84z
10-10-2006 07:30 AM
HybridS130
09-02-2006 05:50 PM
pearly whites
10-30-2003 01:37 PM
saaddaa7
10-24-2003 08:19 PM
Quick Reply: new problem
