internet too slow to search...
Old May 14, 2010 | 07:38 PM
KasbeKZ's Avatar
Pr0n Addict
there's a problem with my internet, and for some reason i'm unable to search here or on any other forum. posting and stuff is slow too, so i'm just asking a question i should be searching for. please help me out!
i finally got the car running after some valve cover gasket/injector replacement work. also replaced IACV connectors with GM style.
i finally get it running, and it's running like ****. bad connection on water temp sensor, now it's a little better. remaining problems are:
1. idles high. holding around 950 now. i did have the AAC apart and took the idle screw out, so obviously i need to reset the base idle. BUT, i let the engine get to op. temp., took the aac plug off, and the engine stalled. wtf... based on the description of the aac that i read, i didn't even think it was possible for the aac to change when not plugged in... so.... what now?
2. i rev, let it drop, and it wavers a bit. not at all sure how to go at that one.
yeah, i checked all connections. yes, it's possible i attached one of the new connectors backwards. i figure, since that's kinda hard to diagnose at this point, i'll do so thngrough doing what you all say to do and have it not work.
thanks in advance. as soon as the car's going again i'll have time to start working on the internet at my f-ing house. i never thought my school internet would be better than at my home.
on a side note, it's now taking multiple attempts to even post this thread. net works intermittently, hence, searches stop mid way.
Old May 15, 2010 | 04:40 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
... this was so much faster, huh?
Old May 15, 2010 | 05:28 PM
KasbeKZ's Avatar
Pr0n Addict
haha no, you're missing me. it's not that searches are slow, it's that they're impossible. i'm not kidding. the internet starts and stops, and searches don't restart once that happens.
now adding some more info...
code 55, but, when i take the water temp sensor off, it makes no difference in how the car runs.
Old May 15, 2010 | 07:30 PM
KasbeKZ's Avatar
Pr0n Addict
so, no help from you? you have to admit, it is a bit of a tricky one.
one more bit of info: passes the pinch test. once warm, pinching the line has no affect on the idle speed.
Old May 15, 2010 | 07:32 PM
Since you mentioned your internet...
Are you using Firefox with Adblock Plus? And AVG anti-virus?
Old May 15, 2010 | 08:33 PM
KasbeKZ's Avatar
Pr0n Addict
i'm not sure if i have adblock, but yes to the other two. it's the same on my mom's computer here though and she's got a completely different browser set up. it's the router i'm sure. what i should do is plug it in, but there are always people downstairs where the box is...
that, and in all the research i've done on idle problems, i've never seen any info on what to do if your car stalls when you unhook the aac!
Old May 17, 2010 | 10:04 AM
KasbeKZ's Avatar
Pr0n Addict
i plugged it in and it didn't help. reset the box, no help. internet is just bummed. haven't completed a forum search in over a week
Old May 17, 2010 | 10:30 AM
KasbeKZ's Avatar
Pr0n Addict
this internet problem is about to ruin me. seemingly, my internet here at home starts and stopsfrequently, but only for split seconds. most page loadings go ok, occasionally needing a refresh, but the real problems are searching forums and watching streaming videos. downloads are a problem as well.
i would be searching or on a computer forum for this, but i can't search ANY forums, or join new forums! i'm just screwed! google searches work fine because they're so fast, but forum searches are slow enough that the internet momentarily stops and restarts and the search does not then continue.
any ideas?
Old May 17, 2010 | 04:04 PM
KasbeKZ's Avatar
Pr0n Addict
is adblock plus the same type of thing as spybot? i do have spybot. should i get adblock too or would that be two of the same type thing?
Old May 17, 2010 | 08:14 PM
domsgarage's Avatar
Tough Guy
might be time to empty out the **** cache...
Old May 18, 2010 | 05:07 AM
KasbeKZ's Avatar
Pr0n Addict
lol my mom's computer has the same problem though so....
Old May 18, 2010 | 06:32 AM
SpeciallySpiked's Avatar
I'm a Registered User!
Again:
Hahahaha call your provider and bitch 'em out!
Old May 18, 2010 | 09:01 AM
Roundabout136's Avatar
^Lmao.
Will, if you need me to search something gimme a call.
Old May 18, 2010 | 09:49 AM
KasbeKZ's Avatar
Pr0n Addict
thanks yo.
new info on the subject: i ran the idle all the way down which got me to about 750, but it runs like **** there and stalled soon after. i'm completely lost now. i have no idea what to do about this idle **** and no idea what to do about my brakes. $1k takes the car.
KasbeKZ's Avatar
Pr0n Addict
thanks yo.
Old May 19, 2010 | 10:29 PM
domsgarage's Avatar
Tough Guy
really?
KasbeKZ
May 14, 2008 10:43 PM
SinCity350Z
Jan 18, 2006 01:34 PM
efrain
Sep 16, 2005 08:23 PM
emo236
Dec 24, 2004 12:00 PM
Z-er
Oct 18, 2004 08:09 PM
