converting km to miles
Old May 13, 2004 | 07:59 PM
rookieszx's Avatar
I have a 90 tt turbo that i recieved from a cousin in canada. I swapped clusters buy now i am not sure what to do to change the odometer from reading in km to miles. I am assuming that i would have to change the chip. Any info would be greatly appreciated.
Old May 13, 2004 | 11:10 PM
Riz Z Speed's Avatar
Administrative Brown Guy
You swapped clusters?
From Canadian to Canadian?
Speed is speed, man. Whether it reads km or mph, you're going the same speed.
Swap in a US cluster, or get new Gauges. Overlays or otherwise.
Old May 14, 2004 | 10:54 AM
rookieszx's Avatar
no, i swapped canadian to american, but the odometer reads in km not miles. another words when i drive a mile the odometer reads 1.6 km. all the gauges are in mph, the odometer calculates km not miles. hope this clears things up.
Old May 14, 2004 | 12:35 PM
DanZ32's Avatar
Dan's the Man
Naw, messing with the odometer is usually an offense, Unless you plan on keeping the car to yourself. Then I suppose you can replace it.
I'm in Canada and bought a US car, so I have the opposite issue. I have everything in miles. You just kinda forget about it and get used to it.
Look at the bright side...everytime you look down you can say damn! I'm getting great gas mileage!
Old May 14, 2004 | 05:20 PM
rookieszx's Avatar
LOL ..good point. I dont think you guys are getting my ?. There has to be some way (legally) that i can get my odometer to calculate miles not km.
Old May 15, 2004 | 05:38 AM
DanZ32's Avatar
Dan's the Man
I here ya! I've never pulled my gauge cluster apart to see exactly how its all hooked up and what its hooked up to. Sorry.
Rizz is the resident expert. If its possible to do, I'm sure he'll figure it out.
Sorry to put the pressure on you Rizz.
Old May 15, 2004 | 08:02 AM
NISMO LMR's Avatar
Why would you "change clips"?... I'm not too sure what you mean there. I could find out for you easily man, I work for a company that imports JDM cars to US, so we have to do all the conversion's and what-not. I'll make some calls.
Old May 15, 2004 | 12:14 PM
rookieszx's Avatar
That would be great...i also need to know how to change the gauges from celcius to fahrenheit. thanks in advance..
Old May 15, 2004 | 11:01 PM
For the climate controls, you have to change over to a us spec climate control computer. As for odometer, I'm still inquiring and researching. Results pending......
Old May 16, 2004 | 09:40 PM
OrangeZ32's Avatar
In my personal opinion i would just say screw it. If it's not broken don't fix it. It's not worth the time or the money to transfer it over when it really won't help you in, other than when you look down you'll say oh look I have this many miles on my car. It'll cost you a lot less to just deal with it.
Old May 18, 2004 | 06:33 PM
I've gotten some info.
I'm kinda skeptical but some have suggested that maybe the speed sensor in the tranny might need to be swapped out to a U.S. unit. I'm thinkin that the odometer won't be affected by a speed sensor since it doesn't record speed but distance. It's worth a try. I'll have to wait to see if I get anymore info.
Old May 18, 2004 | 07:03 PM
rookieszx's Avatar
Maybe its not worth the hassle. I appreciate you looking into it for me. I would however like to get the climate control changed... any idea where i can get the us spec computer.?
Old May 19, 2004 | 01:01 PM
NISMO LMR's Avatar
Junk yard... But then you run into problems.
Non-USDM ECU/M's are set for high impedance* applications... USDM are Low impedance, if you mix the two, it can only cause trouble! Or what computer are you speaking of?
Impedance=resistance
Old May 19, 2004 | 08:44 PM
domsgarage's Avatar
Tough Guy
Just leave it. Then sell the car with really really low miles.
hoov100
Jan 18, 2009 09:34 PM
MadZ420
12
Mar 24, 2006 03:32 AM
FLiPSyDe71
Mar 3, 2004 02:40 AM
GodZilla
Oct 29, 2003 02:13 PM
zexpert
Sep 1, 2002 10:31 AM
