Vibrating
Old Apr 27, 2004 | 10:43 AM
tsefreeflow's Avatar
I'm Chillin
Vibrating
Ok, I am pretty sure this is warped rotors but I will ask anyway. When I break from high speeds my steerinmg wheel shakes pretty badly, but at slower speeds I do not really feel it too much. It started a few months after I put on Axxis Metal Master brake pads. Do these pads cause higher heat from friction or what?
Also I will probably have them turned but I have heard there is a limit to how thick they can be and how much turning they can endure, does anyone know the specs? and can I just take them off and take them to O'riely's to have them do it for $8 a piece?
Thanks in advance
Old Apr 27, 2004 | 01:16 PM
domsgarage's Avatar
Tough Guy
Did you replace your Steering Rod with a 2 foot Vibrator. Because thats what happened to me. I just took the batteries out.
Old Apr 27, 2004 | 02:03 PM
Riz Z Speed's Avatar
Administrative Brown Guy
You should've had the rotors cut at the same time as you installed the brake pads. If it only occurs at high speed then you might have minimal warpage. Cutting them now might solve your problem. But more than likely you'll experience abnormal brake pad wear. You might not get the desired life expectancy from your current pads.
And dom.....what can I say? Better yet, I won't say anything.
Old Apr 27, 2004 | 04:37 PM
domsgarage's Avatar
Tough Guy
True story.
But, I had a new set of rotors put on, and they were a little warped form the start. I drove on them for like 2 weeks and it went away. I was going to have them cut, but I didnt have time, and it just went away. The car stops really nice now that theres no problem. It stopped good with the problem to thou. So I dont know.
Old Apr 28, 2004 | 06:03 AM
I'm Chillin
Damn your right, but I meant to put the vibrator on the shifter. I must of misplaced it to the steering rod. My bad!
Old Apr 28, 2004 | 09:06 AM
domsgarage's Avatar
Tough Guy
Do you see what happened there Rizz. My knowledge has finally surpassed yours.
Old May 10, 2004 | 07:17 PM
91zxtt's Avatar
It's threads like this that cause me to lean back in my chair and LMAO.
Back to the problem at hand. Your tension rod bushings could be worn as well. I had that problem a couple years ago.
Old May 11, 2004 | 01:56 PM
I see what happened there alright, you've had WAY too much to drink. Or better yet pass that over this way so we both can enjoy your euphoric illusion-causing state.
Hrududu
Nov 21, 2005 12:56 PM
Airpilot16
Sep 18, 2003 06:55 PM
ipvega
Jul 16, 2003 09:40 PM
