AC problem
Old Jul 3, 2005 | 12:34 AM
phrozen209's Avatar
AC problem
so this afternoon, i turned on my car to warm it up to go to work (it was like 90 degrees outside and no shade for my Z.....) and i turned on the AC so when i left, the inside would be cool. about 5 mins later, i took off and about 50 feet of driving, i heard a LOUD hiss like a tire deflating coming from under the hood on the driver's side. i turned off the AC, pulled over and opened my hood and the sound was coming from the driver's side, between the engine and the wheel well... the hiss started to die out and then when i went to turn my AC back on, it was hot! I looked in that little window in the AC pipe and no liquid was passing through. what happened?
Old Jul 3, 2005 | 10:15 AM
bardabe's Avatar
Bad Speller
iono from what I'm reading this is just guesstimatin from my point of view. some line in your AC system sprung a leak and all teh freoncame out so your AC has no freon in it and it's emptythat is why your ac is Hot. but that's just my theory coudl be right could be wrong.
Old Jul 3, 2005 | 04:10 PM
phrozen209's Avatar
i think that is what happened. im goin to check the lines today as soon as I can.
Old Jul 3, 2005 | 06:18 PM
v0va's Avatar
Russian Pimp
my ac doesnt work for ****, i just take off the ttops
Old Jul 3, 2005 | 09:10 PM
b300z's Avatar
caught the z fever
my ac takes gas. i just take the t-tops off
Old Jul 3, 2005 | 10:24 PM
phrozen209's Avatar
lol, but the air is also hot, so taking off the ttops makes it worse!
Old Jul 3, 2005 | 11:22 PM
superz's Avatar
My AC works but it trips out... Like it makes a clickin noise and gets weak and then clicks a few more times and returns to normal...
Old Jul 4, 2005 | 05:46 AM
CanyonCarver's Avatar
Jack Of All Trades
You definitely sprung a leak that you're gonna have to chase down. One biatch is that we prolly still have the R12 refrigerant, so even if you do find the leak, you'll need a conversion kit to be able to switch over to the newer R134. I see an AC repair shop in your future.
superz, you might try checking the wire/connector that goes to the AC compressor. Sounds like it might be loose or the insulation has worn thru somewhere and the wire is rubbing metal.
Old Jul 5, 2005 | 07:31 PM
KENZ's Avatar
Silvered Hawaiian
i dont think theres not much ac specialists here. check out an ac shop dude
Old Jul 10, 2005 | 11:45 PM
superz's Avatar
damn... Guess its time to remove the t-tops and stick my bald head out...
Myzsucksass
Nov 28, 2013 06:58 AM
turbo84z
Oct 10, 2006 07:30 AM
HybridS130
Sep 2, 2006 05:50 PM
pearly whites
Oct 30, 2003 01:37 PM
saaddaa7
Oct 24, 2003 08:19 PM
