rough starts
Old Jun 14, 2005 | 12:50 AM
phrozen209's Avatar
rough starts
for a little while now, when i start my car for the first time since a couple of days or hours(usually from one night to the next afternoon), it takes a little while to crank up and run. then when starts, it sounds like it wants to stall, and then goes to normal idling and screeches for a couple of seconds... whats up with my Z?
Old Jun 14, 2005 | 05:06 PM
RPS13_GZ32's Avatar
I'm having a similar prob. only on start ups, but w/o the screeching. Anyone have any ideas, I'm guessing it has something to do w/ the fuel system, like the filter or something, any opinions?
Old Jun 14, 2005 | 06:44 PM
bardabe's Avatar
Bad Speller
i had that problem, I changed Fuel Filter, and added some Injector cleaner, the screechign was my drivebelts everithign turned out nice. also try cleaning teh IAC, that helps alot.
Old Jun 14, 2005 | 08:04 PM
91zxtt's Avatar
^^ I'll 2nd that one.
Good advice Bardabe. If I didn't know better I'd say that you've been paying attention. That's not really your style.
Old Jun 15, 2005 | 12:43 AM
phrozen209's Avatar
i also notice that it happens only when it is hot outside... would this have anything to do with it? and also, the when the screeching stops, the fan starts to move; like maybe if the belt skips when the fan tries to turn on.
Old Jun 15, 2005 | 07:05 PM
91zxtt's Avatar
The screeching is caused by loose belts. In order to take the slack out of the water pump belt, you must adjust the tensionerlocated by the alternator. There's a separate tensioner for the power steering belt and the AC belt. I've had probelms adjusting my own PS belt, so I can't advise the easiest way to do it. The other two are very simple.
It only does it when it's hot? Odd. I'm going to say air regulator. It's part of the IACV assembly. Get your ohm meter. Should read 75 ohms
Old Jun 22, 2005 | 04:33 PM
phrozen209's Avatar
i changed my plugs from Denso Iridiums to the stock NGKs.. i also added injector cleaner and my car has been starting up perfect for the last couple of days.. i changed my fuel fillter yesterday to be safe.
Old Jun 22, 2005 | 04:47 PM
bardabe's Avatar
Bad Speller
the easiest way to tighten all your belts is from the bottom of the car. jack iot up and from teh bottom upyou hvae a perfect view and plenty of room to move arround too. look @ the view you get.
Old Jun 22, 2005 | 07:19 PM
91zxtt's Avatar
I'll 2nd that also.
Woohoo, Bardabe's 2 for 2.
Old Jul 11, 2005 | 11:01 AM
nka04a's Avatar
Iv had the same problem with starting up but not with the screeching. I bought some throttle body cleaner and im going to clean them and replace the throttle body positioning sencer. Also what is the IACV and where is it located....im a z noob. Should i go ahead and replace my fuel filter? My car also idles at 2,000 - 800 RPM im hopeing that the throttle body positioning sencer will fix that.
1995buick
Oct 10, 2011 02:08 PM
renny
Sep 16, 2010 08:36 AM
shaved300zx
Aug 22, 2009 05:40 AM
Mtnangie
16
Aug 6, 2007 10:03 PM
skittle
Dec 11, 2006 06:48 PM
