6 speed TT swap?
Old Sep 24, 2007 | 06:06 PM
  #26
se0nz's Avatar
i thought that people would much rather go with the N/A tranny even with the tt swap for the gearing? if you did that you would have to do all that work tho i believe, bellhousing etc.
Old Sep 24, 2007 | 06:12 PM
  #27
entropy31's Avatar
The Cake Is A Lie!
the NA and TT trannies are geard identical. the rear end is what is different.
Old Sep 24, 2007 | 06:43 PM
  #28
geard identical yes, but some crap with flywheel diameter difference and holds more gear oil suposedly. thats it. rear ends are different and though you can get better acceleration from the NA rearend its supposedly weaker than the TT, plus the TT makes enough power to where you wouldnt give a crap about the rear end difference.
Old Sep 24, 2007 | 08:12 PM
  #29
b300z's Avatar
caught the z fever
the n/a rear end is weaker. but that doesnt mean its worse. a lot of TT guys put in 4.10s for a quicker gear.
Old Sep 25, 2007 | 09:37 PM
  #30
MikeZ's Avatar
http://www.specialtyz.com/gears.htm
just a little sumthn' sumthn'
pretty steep tho'...
Old Oct 12, 2007 | 10:45 AM
  #31
johnsonsz31tt's Avatar
if you shift at 3000 rpm, through six gears its ganna burn more gas then just doing it through 5.....
Old Oct 12, 2007 | 10:51 AM
  #32
If you NEED to be in 6th gear... you're already burning a lot of fuel. Lemme clue ya in on a basic math equation:
MORE SPEED = MORE FUEL
Old Oct 13, 2007 | 03:13 PM
  #33
ZLover4Life's Avatar
Encyclopedic Knowledge
NismoPick - that's an overly simplistic statement. One could create a transmission that'll result in better gas mileage at 200mph than another transmission at 100mph (ignoring the fact that it might take forever to get to 200mph, it'll still do so while attaining better gas mileage). Gearing and final drive determine the RPM at which the engine has to turn to achieve a given speed... with the right gearing, you can go faster while using the same amount of fuel.
In fact, a stock TT at a given speed will get better fuel mileage than a TT with an NA rear end at the same speed simply because the final drive is smaller. If you were to put a 350Z trans on the car and shift into 6th gear, you'd STILL get better gas mileage with the stock TT setup because the 6th gear on the 350Z is larger than the 5th gear on the TT (.794 vs .752), so the engine will turn more rpm at the same speed. Not to mention the .752 5th gear will give you a higher top-end.
And here are some posts concerning 6-speeds in 300ZX's.
https://www.zdriver.com/forums/300zx-z32-performance-technical-47/6-speed-tranny-18451/
https://www.zdriver.com/forums/300zx-z32-forums-7/6-speed-300zx-tt-16419/
Old Oct 13, 2007 | 11:45 PM
  #34
ViperGTO99's Avatar
ZLover.... I'm SO glad you're back to clear things like this up. Now 'Young-Z owners' should just read, comprehend, and learn.
Thanks again for stopping in to check on us.
Old Oct 14, 2007 | 10:34 AM
  #35
Thanks. It's nice to be welcomed back... I figured my absence may have been welcomed. lol
Old Oct 19, 2007 | 11:31 AM
  #36
Riz Z Speed's Avatar
Administrative Brown Guy
the matter sounds closed to me...
as well as this thread.
LQCKQN
Jul 8, 2013 09:47 PM
turbotim
Jul 11, 2010 04:42 PM
turbotim
May 24, 2010 08:59 AM
thxone
May 24, 2006 06:59 PM
peejay910
Sep 30, 2004 07:40 PM
