6 speed TT swap?
Old Sep 19, 2007 | 09:14 PM
KustomZ's Avatar
6 speed TT swap?
I currently have a 91 N/A and am planning a tt swap. I am ordering a full front clip and new clutch, oil pan, fuel pump, and a usdm uncut harness. 1st is there anything else i will need with the swap? 2nd, how do I put a 350z 6 speed tranny onto the swap?
Old Sep 19, 2007 | 09:17 PM
Been asked a gazillion times. Try searching.
PS... welcome to ZDriver!
Old Sep 19, 2007 | 09:23 PM
Murph Z32's Avatar
The 5spd Z32 tranny is fine don't waste your money. Buy some intercoolers or some prostitutes instead.
Old Sep 19, 2007 | 09:48 PM
the Z32 5-spd is much stronger, dont ditch it, it will never fail you, sept maybe the synchros lol
Old Sep 19, 2007 | 10:03 PM
260zturbo's Avatar
Stupid Hurricanes...
why would u want one more gear to begin with? the early 350 manuals had some flaws i think. keep the z32 tranny hey if not ill give u 400 for it
Old Sep 19, 2007 | 10:45 PM
lol, the Z32 tranny swap is pricey for our cars 260, plus isnt the sx trany a very similare design? so shouldnt it be plenty strong for at least 400hp. thats all i really want i know
Old Sep 19, 2007 | 10:47 PM
KustomZ's Avatar
My 5 speed on my N/A is crap. I've gone through 2 trannys and 4 clutches. Every time its the same problem. Synchros. I was hoping the 6 speed with a performance clutch would last longer and i would also be able to save a little gas. lol
Old Sep 19, 2007 | 10:53 PM
theres a site i cant remember if its koz or w.e but they sell the what is it, 97+ trannies for 1600 brand new that are supposed to have eliminated that synchro problem
Old Sep 19, 2007 | 10:57 PM
KustomZ's Avatar
1600 is alot. i can have a tranny custom made for that. Thats also prob without shipping. But thanks for the info, I will look into it.
Old Sep 19, 2007 | 11:01 PM
what do you do to the Z that youve gone through 4 clutches and 2 trannies? im guessing they were used trannies, but as for the clutches, i had mine on for 150k almost before i had to change it, and just changing the fluid fixed my 3rd-4th grinding problem
Old Sep 19, 2007 | 11:08 PM
That means one thing... you're grinding the gears & need to learn how to shift properly.
Old Sep 19, 2007 | 11:26 PM
KustomZ's Avatar
I know how to drive dont worry. I down shift a little much at high rpms. So my clutch slips a little. So I change em. Now its pretty bad but I'll wait since I am savnig for this swap.
Old Sep 19, 2007 | 11:28 PM
^^^ I rest my case.
Old Sep 19, 2007 | 11:33 PM
KustomZ's Avatar
^^^ I rest my case.
I like to have fun in my car. It's w/e. I would rather pop my clutch than pull my ebrake. Its a smoother turn in my case.
Old Sep 20, 2007 | 12:26 AM
dont downshift unless you have too, let the brakes take the beating, their easier to fix..
Old Sep 20, 2007 | 09:38 AM
260zturbo's Avatar
snw no the sx tranny is nothing like the z32 tranny. the sx tranny can hold about 300. the z32 tranny is beefy for the most wicked builds. has a better gearing, the swap a z32 tranny in does not cost as much as u think. actually i know a good friend that has a z32 tranny sitting in his back yard. i just gotta keep it up till finally he gives it to me. then off to a new build on a used tranny i would not pay more then 400 on these trannys.
Old Sep 20, 2007 | 10:38 AM
MikeZ's Avatar
Uhh, what dream world do you live in?
Old Sep 20, 2007 | 10:42 AM
entropy31's Avatar
The Cake Is A Lie!
dont waste your time on this swap. the z32 tranny is stronger than the z33 tranny. and, due to the gearing, you wont save any gas using the 6 speed. you will spend a lot of time and effort to add weight to and subtract reliability from your car.
if synchros are your issue, suck it up and buy this.
http://conceptzperformance.com/Cart/...208.251.96.195
best option.
Old Sep 20, 2007 | 12:40 PM
i know they arent the same but i thought they were "supposed" to be based on somewhat similare designs, and i know the Z32 tranny is like a train. only 300??? ahhh man... thats sooo weak. i was thinking a bit more than that. now i want to use a Z32 tranny. got a swap write-up for that one? and i know the adapter plate is supposed to be a pretty penny.
Old Sep 20, 2007 | 08:31 PM
260zturbo's Avatar
yea u need to send the z32 bellhoushing off to be machined then u have to buy the adapter then u have to cut your transmission tunnel. bolt it on get a custom drive shaft....i have a write up some where....the sx will hold but if u trash it it will give like anything else. im curious to know why u want a BIG bad transmission when ur not even hitting 200?
Old Sep 20, 2007 | 08:42 PM
guys i will be, i dont want a big bad one, i want one that will hold me if i make it to 400, cause i might want to. nahhh, nvm i think ill just sx tranny it, and sell it and get a Z32. lol
Old Sep 21, 2007 | 08:18 PM
91zxtt's Avatar
Did you realize that there's a third way to slow down your car.....it's that pedal in the middle. I don't care how much 'fun' you have with your car or how much you abuse it, but 4 clutches and 2 trannies is a driver problem, not a Nissan tranny problem.
Old Sep 24, 2007 | 04:13 AM
Mousier158's Avatar
Don't forget by swapping in a TT engine your NA tranny wont work unless you use a flywheel/clutch for an NA engine.
Old Sep 24, 2007 | 04:15 PM
KustomZ's Avatar
I'm gunna get a tt tranny.
Old Sep 24, 2007 | 04:18 PM
MikeZ's Avatar
No more 6-speed!!??
