300ztt engine pull
Old Aug 29, 2008 | 10:38 AM
  #51
napoleonzheking's Avatar
F5 Hero
It's a b!tch if it's never been removed before and the precat heat shields are still installed. Try removing the heat shields and use either a gear wrench or a stubby wrench... I don't remember which was easier.
And get downpipes... the starter is SO much easier to install/remove with downpipes installed.
i have the entire exhaust off except the stock DP's coming out of the turbo's.
the starter just sucks.was following the write up on tt.net and it said remove the window heat shield off the starter, i did, and it basically did nothing, did not even need to take it off to get to the lower bolt, helped none on the top, and that heat shield was a BITCH too bc it has a bolt on top as well...
will try stubby wrench, thanks (that is what tt.net says also, just havn't gotten around to trying it yet with my return to school, + work)
*EDIT* Sorry, not trying to thread highjack =)
Old Aug 29, 2008 | 02:40 PM
  #52
Goofyz's Avatar
I have those cheaper downpipes,
paid 160$ for them,so far so good, no problems with them, welds are intact and they have been run hot. It's only been a couple months but summer months, i'll see how they fair after a winter.
Dcap70
Jan 6, 2014 07:56 PM
Dcap70
Jan 3, 2014 08:53 PM
donvito33139
May 19, 2006 07:46 AM
theramz
Aug 12, 2003 08:38 PM
wickedshadowz
Jul 28, 2002 09:19 AM
